watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Well, after all of the various discussions lately about how to remove the glue from the engine firewall, I decided I would try it today. I got about 95% finished, but let me first describe what I did to complete this project.
First off, it appears that no one has found anything that will take the glue off, without removing part of the paint. So with that in mind I decided that I would not only remove the glue, but also the paint. Along with the paint removal, I also decided to remove the tabs, that held up the engine pad, and fill in any extraneous holes. I also had a broken engine lid hinge, so I might as well replace that. OK, first I needed to remove the back pad inside the car. This would allow me to do any welding without burning the pad. First, remove the seats (everyone knows about the tab opposite the adjustment handle needs to be pressed in). Unscrew the engine lid knob. Unscrew the plate behind the knob. Unscrew the (4) screws that hold the back pad. Slightly pull the bottom of the back pad out, which will cause the tabs on the back of the pads to drop down out of the brackets. Attached image(s) ![]() |
watsonrx13 |
Unbolt the lower bolt from the seat belt retractor.
Remove the insulation pad from the car. Since the window rattled, I decided to remove it next. First, lift the plastic covering on the coat hook and screw it. Unscrew the sheet metal screw from the inner targa piece, then remove this piece. Remove the plastic plugs from the targa center piece, then screw the sheet metal screws. I recommend removing the (5) screws that are on the bottom first, then the (7) horizontal screws. Also, start at one side and work your way to the other side. This process can take a long time, as the screws are not always pointed in a direct line, sometimes you'll need to 'fish' around for the screw. Again, take your time. Remove the center piece from the car Carefully remove the rear window. Be careful because it is made of glass. Remove from car. Now that everything is removed from the inside of the car, I can now weld in the engine compartment. There was (5) large holes and various small one. I also had (2) holes that I welded up that was associated with the A/C wiring. Weld in the engine lid bracket. I had earlier gound the tabs off. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 07:30 AM |
