> Ford 9" Transaxle, the lack of
veekry9
post Oct 13 2013, 06:45 PM
OldMember
Group: Retired Members
Hello World.
I posted 1st as a reply to Marcus C6.
How difficult would it be to
fabricate a transaxle that can carry the Ford 9"
ring + pinion?I have viewed Currie's site and see no
mention anywhere online of such a contraption.
A ZF from a Pantera approaches the torque capacity,
the original GT40's box was a Hewland race piece.
(Edit#2:on research,a Colotti tx was used on the 289
mk1's,still in business.)
http://www.colotti.com/
(Edit:Later a KarKraft tx was used,perhaps some
production parts)
Are there any foundrymen on the 914W site?
And of course the latemodel Porsche TX's are works of art.
Could there possibly be a demand for such a high load TX?
vic
duckles
post Nov 5 2013, 04:33 AM
The McKee may be of interest to this brave quest. It's based on the quick change parts that all go back to the early Ford "banjo" style. These lend themselves to theoretical transaxle use because the lack of hypoid offset.
The Ford 9" is a terrible ring and pinion and only gets all this attention because it was used by drag racers decades ago. It's advantage was a removable center section that could be swapped quickly for ratio changes at the track.
The 9" has a very high hypoid offset that is inefficient, it's a sloppy pig that lives on only because of threads like this mentioning it but nobody even cares about center section swapping any more.
I've actually completed a project close to this and created a 928 trans based on a Jerico and 928 diff housing. I used a GM 12 bolt which is a very good R&P design.
The only chance of a custom Porsche configuration transaxle being done without major casting/gear making is going to be the McKee style based on a QC. Even the companies that do make transmissions struggle with delivering. Making a bunch of gears and stuff is a lot of work.
A project like this probably wouldn't be completed even if you were a transmission company!
veekry9   Ford 9" Transaxle   Oct 13 2013, 06:45 PM
kg6dxn   Why not just buy one of these? The R&D is alre...   Oct 13 2013, 07:04 PM
veekry9   Why not just buy one of these? The R&D is alr...   Oct 14 2013, 08:06 PM
914forme   :agree: Or go with an Audi R10 unit.   Oct 13 2013, 07:09 PM
DBCooper   What's the point of a ring and pinion that is ...   Oct 13 2013, 07:37 PM
veekry9   A blown/turbo Porsche or other V8 would likely sna...   Oct 14 2013, 06:36 PM
jimkelly   pic   Oct 14 2013, 06:47 PM
veekry9   Wot duh fouk!! lessee: SBC 400+cid headers...   Oct 14 2013, 07:15 PM
jimkelly   the car went thru many revisions. http://www.yout...   Oct 14 2013, 07:31 PM
r_towle   Sick   Oct 14 2013, 07:34 PM
veekry9   Yeah I remember that car I call it the DragPanzer...   Oct 14 2013, 07:48 PM
Dave_Darling   That's an absurd amount of work. Just get a M...   Oct 14 2013, 08:40 PM
messix   if you intend on drag racing a 914...... well good...   Oct 14 2013, 10:31 PM
bulitt   Ferrari 512bb put the boxer 12 over the top of the...   Oct 15 2013, 04:23 AM
Evil914   Ferrari 512bb put the boxer 12 over the top of th...   Nov 10 2013, 09:21 PM
DBCooper   We've asked what horsepower and what applicati...   Oct 15 2013, 06:47 AM
SLITS   SBC 400+cid headers,cam,750holley largerunner mani...   Oct 15 2013, 09:58 AM
andys   Read this one held 1100HP. It has your 9" An...   Oct 15 2013, 10:23 AM
bulitt   looks like a Tim Allen belt sander.   Oct 15 2013, 12:45 PM
Dr Evil   Hmmmm :popcorn:   Oct 15 2013, 01:26 PM
messix   that would stick out the back of a 914 and more th...   Oct 15 2013, 02:15 PM
veekry9   Yeah. It really is the pursuit of a less expensive...   Oct 15 2013, 05:46 PM
DBCooper   So you don't have an actual application? Ther...   Oct 15 2013, 07:51 PM
veekry9   The application of course is the radical modificat...   Oct 15 2013, 09:02 PM
veekry9   Hello all. I recalled this guy whose work is reall...   Oct 17 2013, 06:10 PM
ThePaintedMan   So let me get this straight, you're going to c...   Oct 17 2013, 06:20 PM
veekry9   So let me get this straight, you're going to ...   Oct 17 2013, 06:42 PM
veekry9   Hello Has anyone here attempted to adapt 944/951/9...   Oct 17 2013, 08:10 PM
scotty b   First off there is no provision for a starter .......   Oct 17 2013, 08:15 PM
veekry9   Hmmm No starter? Not an unsolvable problem as a hi...   Oct 17 2013, 08:22 PM
kg6dxn   The 944 transaxle is almost the same as the VW Fox...   Oct 17 2013, 09:16 PM
Dr Evil   Man, I so want to mess with one of those, Mike. Wh...   Oct 18 2013, 01:34 PM
veekry9   This is great info. Things I need to know before I...   Oct 18 2013, 03:43 PM
veekry9   Allo. After some searching about,I rediscovered t...   Oct 21 2013, 06:00 PM
veekry9   Allo. After some searching about,I rediscovered ...   Oct 23 2013, 01:05 PM
SirAndy   By the way,How does this look to you all? Hate tho...   Oct 25 2013, 04:15 PM
veekry9   By the way,How does this look to you all? Hate th...   Oct 25 2013, 05:14 PM
veekry9   [quote name='SirAndy' post='1946585' date='Oct 25...   Oct 29 2013, 09:10 PM
Mark Henry   [quote name='veekry9' post='1946599' date='Oct 25...   Oct 29 2013, 10:13 PM
veekry9   [quote name='veekry9' post='1946599' date='Oct 2...   Nov 1 2013, 01:33 PM
iamchappy   I know that driveway. :D A little different treat...   Jan 13 2015, 08:17 PM
veekry9   Years ago this fella needed a 5spd ford toploader,...   Oct 22 2013, 08:56 PM
veekry9   Another   Oct 25 2013, 03:44 PM
kg6dxn   From experience, your inlet need to be only half t...   Oct 25 2013, 05:28 PM
Andyrew   ^This. When you have an inlet bigger than your out...   Oct 25 2013, 05:45 PM
veekry9   Ah you see? The objective of the dual rad install ...   Oct 25 2013, 06:08 PM
Dave_Darling   The 2cooler approach has it's own difficultie...   Oct 25 2013, 06:32 PM
SirAndy   That's basically where the headlight lives whe...   Oct 25 2013, 07:17 PM
veekry9   The 2cooler approach has it's own difficulti...   Oct 25 2013, 07:22 PM
Andyrew   Small dual radiators will be a PITA for a v8. If y...   Oct 27 2013, 10:02 AM
veekry9   Small dual radiators will be a PITA for a v8. If ...   Oct 27 2013, 02:53 PM
veekry9   Anyone here ever attempt there 944 trailing arm in...   Oct 27 2013, 05:17 PM
Dave_Darling   You need a bunch more parts to use the 944 trailin...   Oct 27 2013, 09:27 PM
DBCooper   Those trailing arms are late 951 and with some eff...   Oct 28 2013, 06:51 AM
brant   A lot of fantasy talk. Actually building any one o...   Oct 28 2013, 06:57 AM
veekry9   Having discovered 'yesterday' that 944/951...   Oct 28 2013, 04:10 PM
scotty b   Having discovered yesterday that a 951 trailing a...   Oct 29 2013, 08:29 PM
Dr Evil   Saw this and made me think of this thread :shades...   Oct 28 2013, 08:56 PM
veekry9   Saw this and made me think of this thread :shade...   Oct 29 2013, 08:12 PM
r_towle   Saw this and made me think of this thread :shade...   Nov 1 2013, 03:16 PM
veekry9   [quote name='Dr Evil' post='1948315' date='Oct 2...   Sep 6 2014, 05:08 AM
veekry9   Ah so: A torque tube with transverse torsion bars....   Oct 29 2013, 08:54 PM
synackack   I've been thinking about a mendeola transmissi...   Oct 29 2013, 11:58 PM
DBCooper   Nah, not worth it. Hey Veek. As a means of intro...   Oct 30 2013, 07:12 AM
Mark Henry   As a means of introduction could I suggest that ...   Oct 30 2013, 07:29 AM
veekry9   As a means of introduction could I suggest that...   Nov 1 2013, 01:13 PM
brant   The 944/911 did it for packaging purposes. It wasn...   Oct 30 2013, 08:10 AM
Dr Evil   That poor car :(   Nov 1 2013, 01:56 PM
DBCooper   That poor car :( Poor car? Poor cat!   Nov 1 2013, 01:59 PM
veekry9   That poor car :( The car in question is a digit...   Nov 1 2013, 03:11 PM
veekry9   Thanks Mike. I could not believe that the task had...   Nov 4 2013, 07:51 PM
duckles   The McKee may be of interest to this brave quest. ...   Nov 5 2013, 04:33 AM
veekry9   The McKee may be of interest to this brave quest....   Nov 5 2013, 01:08 PM
r_towle   Seems to me the weak spots could be engineered out...   Nov 5 2013, 04:37 AM
914forme   No matter what you build there will always be a we...   Nov 5 2013, 06:52 AM
veekry9   Sure,it's possible.. [url=http://www.gt40s.c...   Sep 4 2014, 06:13 PM
veekry9   XLXUJy7KhBc Turns out the 944S2 tx is plenty torqu...   Sep 5 2014, 12:36 AM
scotty b   so have you started building your car yet ? :conf...   Sep 5 2014, 06:36 AM
veekry9   so have you started building your car yet ? :con...   Sep 5 2014, 09:37 AM
DBCooper   He didn't ask you'd bought a car yet, he a...   Sep 5 2014, 03:37 PM
scotty b   He didn't ask you'd bought a car yet, he ...   Sep 5 2014, 03:52 PM
veekry9   ask a redundant question.. if it's inconvenien...   Sep 6 2014, 01:50 AM
veekry9   Post #76156 Other than the pix, any further info...   Sep 6 2014, 03:32 AM
veekry9   [url=http://www.go2hal.com/index.html]http://www....   Sep 6 2014, 03:42 AM
veekry9   [url=http://blastoland.com/blastoland/BLASTOLAND_...   Sep 6 2014, 05:39 AM
veekry9   16 cylinders=>1000 hp+tq,for high speed gt mot...   Sep 7 2014, 10:25 AM
veekry9   some time later.. How to make a 944S2/951S tx live...   Sep 9 2014, 02:38 PM
veekry9   [url=http://www.gt40s.com/forum/gt40-tech-power...   Sep 14 2014, 11:08 AM
veekry9   GT40-MK IV FE 427 Karkraft T44 TX It's a b...   Sep 19 2014, 06:20 AM
veekry9   A high quality casting a fine example of ability...   Oct 4 2014, 08:52 AM
veekry9   Soon Coming to fruition,a task completed. A Hi-...   Oct 5 2014, 03:21 PM
veekry9   I like your car. Sampled from when you first poste...   Jan 13 2015, 09:23 PM
veekry9   https://griffingearboxes.com/Mid-Engine_Transaxles...   Nov 25 2015, 11:29 AM
Mueller   Incredible this site hasn't returned a sing...   Nov 25 2015, 11:47 AM
24 User(s) are reading this topic (24 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st February 2025 - 11:31 AM
