saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
I lost about 3/4 quart of oil on a recent 1380 mile road trip. Car didn't leak any oil before I left and didn't burn much either. Oil residue is heaviest around the oil filter area and the passenger side of the car, but I see traces of oil all the way from the top of the firewall pad to the rear valence. I may have more than one leak. Engine bay got hot enough that the fuel pump vapor locked on the trip. Pushrod tube seals look good. Does this sound and look like failing oil cooler seals? How big of a job are they to replace?
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) also know your other areas to check then clean it and watch it. if an area is tough to reach use some brake cleaner. autozone has some lo voc vanilla scented stuff that actually smells good. there are a few plugs on the front of the engine, oil pump, etc. any oil leak you have one of these cars will go everywhere so it's hard to tell if it's oil coated. don't forget the valve cover gaskets.
Lo-Fi Version | Time is now: 25th June 2024 - 08:07 PM |
