Want to Add A Start Button on Dash, ...keep bending my key |
7TPorsh |
Nov 18 2013, 12:54 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I keep bending my key starting my car. Is it hard to add a button on the dash where I can turn the ignition on with the key but push the button to crank the starter?
I have the button with two terminals. Is it simply one goes to 12v (fused?) and the other goes to the starter? or do I need to mess with the ignition switch? |
toolguy |
Nov 18 2013, 01:16 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
You might think about leaving everything as is at the ign switch. and add a secondary relay at the solenoid to opperate the starter. . that way you won't need a large capacity {amp} button and can run a smaller gage wire to the relay from the button. . OR you can find the wiring under the dash for the heated rear window switch and use that to get back to the engine compartment. .
The negative side of this idea is you might inadvertently hit the button with the engine running. . . OR you can pull the large yellow wire from the Ign switch which goes to the solenoid, move it to a button with a 12V jumper from the large common battery post under the dash. . . however now your button can operate the starter with the IGn switch being off or on. [think bump button] |
Lo-Fi Version | Time is now: 29th June 2024 - 02:32 AM |
