McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
EDIT: I know about tube-and-water setups. You can't drive with those. I'm building some different.
I've been pondering this project for awhile, and now I'm finally getting ready to start. Every time I synch carbs I think about how terrible and approximate the process is. What I'm going to try is using a small, programmable computer called an Arduino. There are add-ons called Shields to expand the functionality, and I'm using a LCD screen shield. I'm going to hook up 4 to 6 MAP sensors to the Arduino and output their readings on the screen. Using this tool, I'll be able to numerically evaluate the relative balance of the carb throats. One possible shortcoming is that the intake pulses may create fluctuating values that are difficult to interpret. Although, I have some ideas that may deal with this. Some sort of averaging could help. (IMG:style_emoticons/default/idea.gif) Here's what the Arduino looks like (this is the Uno version) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898348.1.jpg) Here's the screen shield (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898349.2.jpg) Here's the MAP sensors I'm going to start with. (IMG:http://www.914world.com/bbs2/uploads_offsite/thumbs4.ebaystatic.com-419-1381898350.3.jpg) I'm also probably going to have to make some plates that will go between the carb and manifold with a vacuum port on it. This would be the easiest way to access manifold vacuum since I can't count on carbs to have vacuum ports. Oh, and this will also be useable while driving to evaluate dynamic synch. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Can you use an airflow sensor for what you are doing?
At the end of the day, it's a wire suspended across a tube/cylinder. Seems you could cut that down to an inch or less in height.. Or incorporate it into a velocity stack. I do love the idea... |
Lo-Fi Version | Time is now: 25th June 2024 - 01:00 AM |
