Help! Rebuilt Carbs, Now Engine Car Shudders at 4k RPM |
'70PVW914 |
Nov 11 2013, 12:07 AM
Newbie Group: Members Posts: 29 Joined: 1-November 13 From: Boulder, Co Member No.: 16,594 Region Association: Rocky Mountains |
Hey folks. I just rebuilt the weber IDF 44 carbs on my 914-2.0 because I was experiencing hiccups/stutters in acceleration from idle to about 3k rpm. Also, the car would idle very low, and then die if you did not give it a good amount of revs after starting. I figured my idle jets were clogged, and since the carbs had not EVER been rebuilt, I re-gasketed, and rejetted them.
Just finished that today, put in new fuel line to the carbs, changed the fuel filter, and troubleshot a strange problem where my accelerator cable seemed to wrap its way around the clutch cable and bind. :headbanger After all of that.....my car is STILL acting very strange; in some ways things are better, and in some, things are worse! NOW: The car seems to idle just fine at a very nice 900rpm after adjusting the idle and throttle body.----SWEET! The accelerator cable seems to stick slightly, also, the ball joint for my accelerator pedal seems to keep popping off of the pivot point (Is there a trick to this, or is the ball joint just shot?!) Seem to have it on there now, but now guarantees! ---LESS SWEET Still seems to stutter when reving in gear b/w idle and 2.5k rpm...same as before I rejetted and cleaned (IMG:style_emoticons/default/dry.gif) Shudders and looses power at 4k rpm in every gear...this thing had crazy power after 4k before I messed with anything. (IMG:style_emoticons/default/mad.gif) When I replaced the float needles and seats that came with the rebuild kit, I noticed the seats were way smaller on the rebuild. I DID NOT adjust the float level....my first culprit for this less than stellar performance. After reading some posts on here, it sounds like the float should be at between 12.5mm and 13mm from the upper face of the carb. Would this solve these problems? Also, I DID remove the throttle valves for a clean and inspection when rebuilding...I am hoping this is not the root of the problem, as they do not seem as smooth as they once were. Don't think its the resize in jets, as I just changed idles from .45 to .55, and air corrections from 200 to 190 as per recommendation. Where should I start here!!!????? I figure I will measure and adjust the float tomorrow, after I remove the carbs again (damnit). But if that doesn't work...what should I be trying?.....Damn weber book didn't get here in time and I am not the most patient..... |
ChrisFoley |
Nov 18 2013, 05:59 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The broken leg is a bit too delicate to weld back on, but a good aluminum welder can build up the remaining leg so a fresh hole can be drilled.
I wouldn't bother trying to reproduce the split though. |
'70PVW914 |
Nov 19 2013, 07:02 PM
The broken leg is a bit too delicate to weld back on, but a good aluminum welder can build up the remaining leg so a fresh hole can be drilled. I wouldn't bother trying to reproduce the split though. Thanks man, this sounds like the most viable option! Gonna take it to get welded tomorrow....shouldn't be but a few sheckles i'd imagine. After that I'm all set with new gaskets to do the valve adjustment, clean out my heater boxes, the carbs and the float adjustment, then sync and tune! Goal is to have her purring in my driveway by this sunday! Looks like I may even get a day of skiing in before then! Living in Colorado totally sucks! (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:57 AM |
