Self Sustaining Electric 914, jwalters is back |
1jwalters |
Nov 16 2013, 08:09 AM
Newbie Group: Members Posts: 28 Joined: 15-November 13 From: Florida Member No.: 16,651 Region Association: None |
http://www.indiegogo.com/projects/self-sus...c-car/x/5342378
My latest project. Recently I designed a new generation wind turbine. I am going to miniaturize my design and work it into the front trunk area of a teener. My goal is to drive coast to coast non-stop........ Ambitious? Yes! Doable? Yes! I will accept any help thrown my way! (IMG:style_emoticons/default/drunk.gif) By the way, it is great to be back here, I missed this place! |
stugray |
Nov 19 2013, 09:33 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE It is a 20KVA genset that measures appx 10 inches long and 6 inches in width. It drives our radar system requirements using hydraulic fluid under pressure turning a motor......And that hydraulic motor is tiny, tiny, tiny compared to the genset/// Where does it get it's hydraulic pressure? A tiny little fraction of a watt windmill? QUOTE So when you guys start citing "laws of thermodynamics this, and laws of perpetual motion that" you are all way, way wrong.......on a total other planet even.. So the planet you are on is apparently not this one. So you have either figured out how to drive a 914 down the road with a fraction of a watt of power, or you have figured out windturbine technology that multi-billion dollars worth of reasearch money has not. Good for you. |
1jwalters |
Nov 20 2013, 07:52 AM
QUOTE It is a 20KVA genset that measures appx 10 inches long and 6 inches in width. It drives our radar system requirements using hydraulic fluid under pressure turning a motor......And that hydraulic motor is tiny, tiny, tiny compared to the genset/// Where does it get it's hydraulic pressure? A tiny little fraction of a watt windmill? QUOTE So when you guys start citing "laws of thermodynamics this, and laws of perpetual motion that" you are all way, way wrong.......on a total other planet even.. So the planet you are on is apparently not this one. So you have either figured out how to drive a 914 down the road with a fraction of a watt of power, or you have figured out windturbine technology that multi-billion dollars worth of reasearch money has not. Good for you. No, the hydraulic pump is located on the accessory section of the Honeywell ATF3-6 turbo-fan engine. It is about 6 inches tall and on a 4 inch bolt circle. This pump feeds the hydraulic motor which operates the 20KVA genset. Many, many aircraft utilize this type of apparatus. It is known as as a C.S.D. or Constant Speed Device... Hey man, just because you apparently are not aware of aviation technology......well.......why are you so dismissive of what you do not know? It is your opinion but man, your coming off as a colossal jerk brother... |
Lo-Fi Version | Time is now: 29th June 2024 - 06:55 AM |
