nomedulla |
NOMEDULLA ![]() Group: Members Posts: 32 Joined: 22-March 06 From: SWFLA Member No.: 5,759 Region Association: South East States ![]() |
EDIT
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I always do these type of triage things with a few assumptions.
I did something wrong.,.. The simplest thing is typically the issue. So, what did you touch, back track. If you pulled out the spade to solder...what else did you disturb in the process. Its not like there is plenty of slack in that harness. You would have disturbed (possibly) all the Injector grounds (passenger side, under the plenum, top case bolt near rear) AAR Distributor EFI trigger points Coil wiring I think that is all that is over there....but you may want to just follow the wiring loom for the EFI and check every connection, reseat all of them, etc. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:17 PM |
