dknechtly |
Yellow 914 ![]() ![]() Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None ![]() |
I have my engine pulled apart for a rebuild. As expected the pistons were carboned up and I dreaded the chore of cleaning. I found this stuff called "Piston Kleen" and let them soak a couple of days. It took the carbon all off! Outside, underside, ring grooves. Some places I just wiped off a little bit. It did a great job. Saved a lot of work and potential piston damage. I just wanted to pass along the good info.
I couldn't find it retail anywhere. Just ordered from the web site. Free and fast shipping. http://www.orisonmarketing.com/pistonkleen.html Edited: I have plain old 1.7 original pistons. When I was researching this, I did see some of the cleaners harmed aluminum. This does not. Just gives you nice, clean, unscratched or scraped pistons. |
Matt Romanowski |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 ![]() |
I believe it was an early form of alusil, like in many Porsche engines. These still use a aluminium piston but it has iron impregnated into the surface. The bore is what is impregnated with silicon, the pistons are bare. You can moly coat or DLC the pistons, but that is not what Porsche has done. They do nikasil on the bores. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:23 AM |
