type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
So, I have my gas tank out and painted it yesterday and now am looking for replacements for the pads under the tank. The one I took out looked like it was made out of cloth or cotton-ish material. In searching for a replacement that won't hold moisture (the one I took out looked like it caused a small patch of rust on the tank which I cleaned before painting) so I was in a dollar store and found a 5 pack of scrubbing pads. PERFECT, $1 for 5 pads which only need to be cut on one side to match the original size; the thickness was a great match. Now I'm second guessing my selection in that this scrubbing pad might scrub off the paint on the body and tank. I wonder if it would move enough to scratch off the paint? What do you think?
somewhat related thread: http://www.914world.com/bbs2/index.php?sho...=203920&hl= |
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
Hmmmm... good one.
I think, if the tank is secured well, it shouldn't shift around to cause wear. If you try it, check it out in a year to see how it holds up. I used some foam pipe insulation with one sticky side. It holds itself in place while you handle the tank. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:15 PM |
