type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
So, I have my gas tank out and painted it yesterday and now am looking for replacements for the pads under the tank. The one I took out looked like it was made out of cloth or cotton-ish material. In searching for a replacement that won't hold moisture (the one I took out looked like it caused a small patch of rust on the tank which I cleaned before painting) so I was in a dollar store and found a 5 pack of scrubbing pads. PERFECT, $1 for 5 pads which only need to be cut on one side to match the original size; the thickness was a great match. Now I'm second guessing my selection in that this scrubbing pad might scrub off the paint on the body and tank. I wonder if it would move enough to scratch off the paint? What do you think?
somewhat related thread: http://www.914world.com/bbs2/index.php?sho...=203920&hl= |
wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
I used 2" wide rubber mastic wire splicing tape found at electrical supply houses. I think I doubled it up. 3m akes good stuff
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
I used 2" wide rubber mastic wire splicing tape found at electrical supply houses. I think I doubled it up. 3m akes good stuff You are fine the way that you did it. These cars will see less and less miles per year per year. I would be remiss not to say that the original was high density felt. Available as hats and shoe inserts. A bit of something the brits use called waxoyl would keep it from ever rusting, but so would any oily waxy substance. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:22 PM |
