worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Here in Wisconsin the winter is always around the corner. The weekend was warm and windy, but single digit temps later this week.
Which means I will be able to weld and wrench, but I cannot paint. So after replacing trunk, floor tunnel and firewall pieces and grinding the welds smooth and fixing the clutch tube and adding the RJ mount, I shot a coat of DP40 over the inside of the tub and the floor above and underneath. I discovered that painting upside down is less burnish than welding upside down. Actually I think it is DP-50 epoxy primer (grey). I generally try to put it on below anything else like bond or high build primer. All of the rust is gone and replaced with solid metal across the whole car. So, I got that going for me. |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Hey! what's wrong with Ravenna? (IMG:style_emoticons/default/happy11.gif)
![]() And: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 06:18 PM |
