new B to 914's, 'restored and garage kept' hmmmm |
varmint |
Jul 27 2004, 11:55 PM
Newbie Group: Members Posts: 6 Joined: 27-July 04 From: Gulf Breeze, Florida Member No.: 2,412 |
hello everyone
Just joined the club but I've been reading and learning for a couple of weeks now. I bought the 914 in Tampa a couple of weeks ago on Ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAP...2483069182&rd=1 and have been busy fixing tail lights, blinkers, horn, etc. I still have brake light issues as the PO has apparently made several modifications to the wiring. I also have a backfire on decel and will drive the car on ramps (scary) to check for exhaust leaks. I'm having 2nd thoughts after reading that the motor must be dropped to change a clutch! I am no mechanic and I hope that I can find a reasonable one in this (Pensacola) area. Looks like most of you are in the CA area? |
SLITS |
Jul 28 2004, 12:09 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Welcome and take your place amongst the insane. (IMG:style_emoticons/default/wacko.gif)
You do not need to drop the motor to change the clutch. You jack up the rear, place jackstands to hold the car up, put a floorjack under the engine and put pressure on it. You then disconnect the axles, shift linkage, clutch cable, speedo cable, starter, tranny ground strap and the rear 4 bolts that fasten the tranny to the body. You then lower the engine about 2-3 inches and wella, you can then pull the tranny. Much easier if you have access to an overhead lift. There are a bunch of you down you way - stand by - they'll probably pipe up soon. Buy a Haynes Manual for some of the information - ask the rest here. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:57 PM |
