> Clutch tube fixes
JRust
post Jan 10 2003, 08:12 PM
Hey Brad you were right about my clutch tube. That was my problem. I put in 2 ubolts in the acces where the shifter is. Spaced about 10" apart. That strengthened it considerably. I'm plannng on putting a few welds on those (inside & underneath the car). For where it comes thru the firwall. Would it hold to just weld where it comes thru the firewall. Or does it need to be on the inside? Anyone? Planning on welding monday & want to make sure this will last! Thanks in advance! (IMG:style_emoticons/default/beerchug.gif)
Brad Roberts
post Apr 28 2003, 04:56 PM
914 Freak!
They break because people dont run the floorboard and the tunnel rusts. The floorboard has a clutch pedal and gas pedal stop on them for a reason. If you dont have the board in place or the stop adjusted correctly.. it pull's the cable up when you try to over extend it by pushing the pedal past where the stop should have been. We caught this one before it broke at the firewall.
B
JRust   Clutch tube fixes   Jan 10 2003, 08:12 PM
Brad Roberts   Honestly Jamie.. I would cut the tunnel and weld ...   Jan 10 2003, 08:57 PM
Gint   It's stupid to wish this on myself (or jynx th...   Jan 10 2003, 09:30 PM
jkeyzer   Guess what... I have to do this repair too. I n...   Feb 6 2003, 02:16 AM
GWN7   Several methods for cutting into the tunnel. Sawsa...   Feb 6 2003, 02:58 AM
chunger   or, use the cutoff tool to cut off the end of a sh...   Feb 6 2003, 03:08 AM
boxstr   Jamie Make the repair but do it correctly, you may...   Feb 6 2003, 10:17 AM
Bleyseng   The welding part is the easy part. It is all the c...   Feb 6 2003, 11:02 AM
Jeffs9146   Beeee Verrrrrry Carefull not to tag the fuel line ...   Feb 6 2003, 11:03 AM
jkeyzer   I'm planning on using MIG to do the welding. ...   Feb 6 2003, 11:57 AM
Bleyseng   I assume that you would drain the gas tank, pull t...   Feb 6 2003, 12:56 PM
Jeffs9146   I did remove the tank and drained what I thought w...   Feb 6 2003, 01:42 PM
JRust   I did use the u-bolts :( . I am going to fix it ri...   Feb 6 2003, 07:51 PM
Kerrys914   Welding is the way to go..if that is an option. I...   Feb 6 2003, 08:57 PM
Brad Roberts   http://www.all914.com/projects/Drobbins/cl...befix...   Apr 28 2003, 04:24 PM
Dave_Darling   Did that thing you put into the end of the clutch ...   Apr 28 2003, 04:31 PM
Brad Roberts   I dont know what it was used for prior to having o...   Apr 28 2003, 04:35 PM
jonwatts   I really like that fix. Tell me again (cuz I forge...   Apr 28 2003, 04:41 PM
L8Apex   hmm, new project to start on.   Apr 28 2003, 04:42 PM
Demick   Nice pics Brad. Good tip on the tube filler thing...   Apr 28 2003, 04:54 PM
Brad Roberts   They break because people dont run the floorboard ...   Apr 28 2003, 04:56 PM
Demick   Isn't the clutch pedal stop built into the clu...   Apr 28 2003, 05:01 PM
silver six   Brad, Clever idea with the shaft that slips insid...   Apr 28 2003, 05:04 PM
anthony   Demick, there's a rubber stop on the floorboar...   Apr 28 2003, 05:05 PM
Dave_Darling     Apr 28 2003, 05:07 PM
Demick   Thanks, I'll check for the stop on the floorbo...   Apr 28 2003, 05:09 PM
jonwatts
  Apr 28 2003, 06:38 PM
URY914   Do you use a right hand or left hand welder to do ...   Apr 28 2003, 07:10 PM
Bleyseng   It started rusting after you and Andy used the san...   Apr 28 2003, 07:32 PM
swood   So would you all agree that this is a fix now or f...   Apr 28 2003, 07:56 PM
L8Apex   They should name the 914's, F.O.R.D. Fix Or Re...   Apr 28 2003, 08:41 PM
Jeffs9146   Here is a picture!! Jeff   Apr 28 2003, 08:51 PM
Brad Roberts   Demick, Sorry I didnt get back to this thread ear...   Apr 29 2003, 02:11 AM
22 User(s) are reading this topic (22 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st January 2025 - 08:55 PM
