georgia914 |
Newbie ![]() Group: Members Posts: 14 Joined: 28-July 04 From: Hogansville, Ga. Member No.: 2,413 ![]() |
Hello to all!
I am a nu b 2. Just got my first 914, and am excited about the work ahead. (not really the work as much as the result) Anyhow... I immediately bought a nice dual weber setup and electronic ignition setup off ebay. Here's my problem, can't find directions or pictures for setting up linkage, throttle cable routing, and manual choke setup. I have the hex bar linkage but have never seen one installed. I don't even know which way the carbs face... Helllllpppp!?? |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Your setup should work okay on your engine. Pull the jets and post what you have (mains, idles, air corr, emulsion tube) and also post the venturi size. Someone here will be able to give you a jet recommendation as good starting point.
For manuals, I recommend the Haynes Weber manual. It has good illustrations to help identify parts and a good tuning sequence. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:47 PM |
