Intermittant Bucking, like fuel is cut off for an instant |
Bruce Allert |
Jul 26 2004, 08:22 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
isn't that the Throttle Position Switch that does that or is it the Injector Points? I also ohmed the Cylinder Head Temp sensor while it was cold & got 3 ohms. Does it need to be disconnected from the ECU wiring before ohming? I did on the cold test but not on the hot. The hot reading (while still connected) was somewhere btwn 1 & 2K. It's supposed to be 3K.
I could not find any vacuum leaks but idle will not go below 1K. I'm getting ....... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/chair.gif) ready to do sumpin drastic (IMG:style_emoticons/default/fighting19.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) ..........b |
ClayPerrine |
Jul 28 2004, 11:03 AM
Life's been good to me so far..... Group: Admin Posts: 15,580 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
QUOTE(georgia914 @ Jul 28 2004, 08:59 AM) Hey my car does that too... only @about 4000. and some times as I roll to a stop it just shuts down. I just bought this car and know nothing about them... Where is the throttle position sensor? Your's is a 1.8L. The injection system used on the 2.0 and the 1.7 is a D-Jet system. The 1.8 uses an L-Jet system. Completely different. The L-Jet doesn't use the throttle switch like the D-Jet. The throttle switch on the L-Jet only has 2 contacts, one for idle, and one for wide open throttle. Clay |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:52 PM |
