stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I need to know what "sandwich adapter" to purchase.
I have one, and the key parameters are: thread that goes "onto" the stock filter bracket (adapter that filter threads onto) size of fittings that go out to remote oil filter I eyeballed the fittings that come from a sandwich adapter that I already have and it "looked like" 1/2" NPT, but the threads into the fitting are smaller. I want to route from the sandwich adapter to 12AN to run to the front coolers for now. Anyone have experience with high flow sandwich adapters? It looks like I have enough meat to tap the sandwich adapter that I have up to 1/2" NPT but curious what others have done. Next upgrade is blockoff plates and the full monty, but right now I would just like to hook 12AN fittings to a sandwich plate and run the stock filter adapter with filter. I might even be interested in the thermostatically controlled adapter plates if anyone has experience. Edit- And while I am at it: does the feed to the oil pump come into the middle of the oil filter? |
stugray |
QUOTE Good luck with your project. Thanks (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1379129795.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1377216116.3.jpg) I have better pics that show the carbon fiber ducts & the exit holes in the fenderwell. One on each side, now I need to plumb them with 12AN hose down the passenger side heater duct. Then to the adapter. Next year I will redo the plumbing from the engine to eliminate the sandwich adapter and probably add a remote oil filter bracket and a thermostat. |
Lo-Fi Version | Time is now: 2nd July 2024 - 07:54 AM |
