> Heater fan operation, troubleshooting
malcolm2
post Dec 14 2013, 08:34 PM
The only thing installed on my car that is associated with HEAT would be the exchangers. Nothing else. I need to get the heat working so I started with the Heater fan in the engine bay.
SO FAR:
successfully bench tested the fan with 12v.
Put a known good headlight relay in the fan relay socket
Successfully checked continuity of the wire from the lever to the 14-pin connector (GRN/wht). Connector attatched, and unattached
Successfully checked continuity from the relay (87) to the fan (green wire), car was not running.
Strange thing I noticed. Checking continuity from the lever to Pin #9 was good. I then checked continuity between the lever and pin 13, 11, 7, 5, 3, 2 & 1. With the 14-pin connector connected they all showed continuity to ground. THIS CAN"T BE RIGHT, can it? The car runs fine, all the lights work. Seems like a ground short, but it is not affecting anything else.
My goal here was to (as designed) get 12v to the green wire on the fan, but I can't. I have read several posts that gave me some direction. But I am lost.
Thanks,
Clark
etcmss
post Dec 15 2013, 06:15 AM
etcmss
I've done this a couple of times and briefly remember just getting the 12 volts from pin 11 to the fan and it worked fine. if the lever arm switch is working through the relay then it should be ok.
- Lo-Fi Version Time is now: 15th January 2025 - 05:54 AM
