Jetsetsurfshop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States ![]() |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
Jetsetsurfshop |
I didn't like the idea of running the oil lines all the way up there in fear of the oil pressure falling off to much.
Also worried about creating lift with the bottom exit of air. I'm I stressed about nothing? The accusump is a mystery to me. (IMG:style_emoticons/default/WTF.gif) I pull in to the pits, car is at idle and I shut off the accusump. It seems to me that the oil viscosity is thinner at temperature and won't travel back up the pump? Once the oil temp has dropped to 160ish I can fill it back up. I just don't like all that oil sitting in the crankcase. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,713 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Also worried about creating lift with the bottom exit of air. Does your class allow for a hood vent? If so, create some extra downforce and vent out the hood ... (IMG:style_emoticons/default/smile.gif) http://www.914world.com/bbs2/index.php?s=&...t&p=1898832 |
Jetsetsurfshop |
Also worried about creating lift with the bottom exit of air. Does your class allow for a hood vent? If so, create some extra downforce and vent out the hood ... (IMG:style_emoticons/default/smile.gif) http://www.914world.com/bbs2/index.php?s=&...t&p=1898832 I'm just doing DE's right now and I don't worry about class stuff to much. I enjoy engineering my car as much as running it. (IMG:style_emoticons/default/driving.gif) A hood vent would be my first choice though. |
Lo-Fi Version | Time is now: 1st July 2024 - 03:13 PM |
