> Best way to add heat to a Subaru conversion?
CptTripps
post Dec 16 2013, 08:30 PM
:: Punch and Pie ::
I would like to add heat and defrost to my Subaru conversion, but I'm not sure the best way to do it. Now, I'm no expert on the ventalation system of these cars, but I was hoping to have something simple like 2 discrete motors. One for the vents on the dash, and another for the defrost.
The stock heat blowers are intact on the car, but I don't believe they're hooked up at all, since the PO had a SB350 installed. That motor is going bye-bye, and I'm not sure the best way to add something to replace it. I don't need fire shooting out of the vents like my Land Rover, just enough to get the windscreen clear and take the edge off of a cool night.
I see a few aftermarket blowers that I can put in-line with the heat tubes, but how should I GET the heat? Is thee a way to do it from the water in the radiator?
nsyr
post Dec 19 2013, 10:01 AM
Because I Can
I hear you. I saved all the hvac stuff from my svx, that's how I know. What would be ideal is a unit that could fit in the existing fresh air blower area. That way all the original vents and defroster vents could be used.
Chris H.
post Dec 19 2013, 01:07 PM
QUOTE(nsyr @ Dec 19 2013, 10:01 AM) *
I figured you were ahead of me on this one Andrew. Yeah IDEAL for me would be something you could stuff behind the dash so you couldn't see it and the car just appeared fairly stock using the stock vents as you said. Once you remove the stock fan controls and radio there is quite a bit of room back there (under there...?). Then use electronic controls like the SVX has so it could be controlled somewhat remotely. Easy to say...hard to do.
CptTripps   Best way to add heat to a Subaru conversion?   Dec 16 2013, 08:30 PM
bfrymire   I would like to add heat and defrost to my Subaru...   Dec 16 2013, 08:47 PM
bulitt   Do a search under Marks914. He put an oil cooler ...   Dec 16 2013, 08:59 PM
McMark   I'd look at a motorcycle oil cooler, mounted i...   Dec 16 2013, 09:30 PM
Mike Bellis   I did an oil cooler in the fresh air box. I did a ...   Dec 16 2013, 09:34 PM
Tilly74   For my subie swap I plan to modify my fresh air bo...   Dec 16 2013, 10:06 PM
BIGKAT_83   Like mine here. Both heat and AC. Still have to f...   Dec 16 2013, 10:22 PM
mepstein   Like mine here. Both heat and AC. Still have to ...   Dec 17 2013, 08:57 AM
nsyr   Like mine here. Both heat and AC. Still have to ...   Dec 17 2013, 12:41 PM
Mike Bellis   Here's my heater thread... http://www.914worl...   Dec 16 2013, 10:23 PM
gryphon68   Considering this myself. This is where I'm ...   Dec 17 2013, 08:03 AM
DBCooper   Wow, Bob, EXTREMELY sanitary! And you actuall...   Dec 17 2013, 08:22 AM
CptTripps   Yeah, I'm waiting for that explanation too...   Dec 17 2013, 01:35 PM
Chris H.   Is this what you used Bob?   Dec 17 2013, 01:48 PM
BIGKAT_83   Is this what you used Bob? I was going to use...   Dec 17 2013, 03:27 PM
mikesmith   The unit you linked is one of the Vintage Air unde...   Dec 17 2013, 01:54 PM
gryphon68   The unit you linked is one of the Vintage Air und...   Dec 17 2013, 02:14 PM
Chris H.   Ah OK. I was trolling all his old threads...we...   Dec 17 2013, 02:05 PM
CptTripps   I'm looking at this, thinking it may work well...   Dec 17 2013, 02:17 PM
badmiata   I have seen the under dash ones. Renagade, Pelican...   Dec 17 2013, 02:34 PM
andys   I have seen the under dash ones. Renagade, Pelica...   Dec 17 2013, 04:08 PM
ThePaintedMan   Bob's setup is really cool. Would love to find...   Dec 17 2013, 02:40 PM
914skraper   So, challenging one of the basic assumptions, it o...   Dec 17 2013, 04:18 PM
ruby914   So, challenging one of the basic assumptions, it ...   Dec 18 2013, 10:47 AM
mikesmith   I have seen the under dash ones. Renagade, Pelica...   Dec 17 2013, 05:11 PM
Chris H.   I saved all of the SVX hvac system hoping to use i...   Dec 18 2013, 09:47 AM
mgp4591   I saved all of the SVX hvac system hoping to use ...   Dec 18 2013, 10:24 PM
JRust   I have a unit that came in a Rotary conversion. I ...   Dec 18 2013, 11:29 AM
jaxdream   I have a unit that came in a Rotary conversion. I...   Dec 18 2013, 01:05 PM
andys   Just an opinion on drawing fresh air from the engi...   Dec 18 2013, 01:16 PM
JRust   Just an opinion on drawing fresh air from the eng...   Dec 18 2013, 05:56 PM
nsyr   The svx evaporator and fan assemblies are too big ...   Dec 19 2013, 07:28 AM
partwerks   I have the under dash unit from Renegade. I'm...   Dec 19 2013, 07:47 AM
Chris H.   Re: the stock SVX unit: They are BIG that's fo...   Dec 19 2013, 08:03 AM
nsyr   I hear you. I saved all the hvac stuff from my svx...   Dec 19 2013, 10:01 AM
Chris H.   I hear you. I saved all the hvac stuff from my sv...   Dec 19 2013, 01:07 PM
okieflyr   I've used McMark's system for 7+ years now...   Dec 19 2013, 09:58 PM
CptTripps   I ordered this one today. I'll let you all kno...   Mar 6 2014, 01:01 PM
sixnotfour   the other benefit to AC is that it dehumidifies in...   Jun 25 2014, 12:25 PM
- Lo-Fi Version Time is now: 11th January 2025 - 08:41 AM
