recent Sebring Abuse, Oil system help |
Jetsetsurfshop |
Dec 17 2013, 10:32 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
brant |
Dec 17 2013, 09:29 PM
914 Wizard Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
if you don't want to use it, just shut the valve and make sure the oil level in the motor is correct...
but these cars have a significant oiling problem in stock trim during cornering.... I installed a 2nd large oil pressure warning light on a 15lb pressure switch and could light it easily when I forgot to turn on the accusump. you need some kind of additional oil modifications over stock for track work. brant |
Seabird |
Dec 19 2013, 02:08 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
if you don't want to use it, just shut the valve and make sure the oil level in the motor is correct... but these cars have a significant oiling problem in stock trim during cornering.... I installed a 2nd large oil pressure warning light on a 15lb pressure switch and could light it easily when I forgot to turn on the accusump. you need some kind of additional oil modifications over stock for track work. brant A little bit of a highjack here, sorry. Brant when you say stock trim you mean without the tunacan/larger sump? Or am I to understand that a accusump is necessary equipment for track applications? Miguel |
brant |
Dec 19 2013, 05:00 PM
if you don't want to use it, just shut the valve and make sure the oil level in the motor is correct... but these cars have a significant oiling problem in stock trim during cornering.... I installed a 2nd large oil pressure warning light on a 15lb pressure switch and could light it easily when I forgot to turn on the accusump. you need some kind of additional oil modifications over stock for track work. brant A little bit of a highjack here, sorry. Brant when you say stock trim you mean without the tunacan/larger sump? Or am I to understand that a accusump is necessary equipment for track applications? Miguel Miguel, I think I was a little vague because there are lots of opinions I believe the tuna can with extended pick up will help A LOT, and may be good enough.... that being said, my own belief is that a small accusump is even a little better we used to run both on our 4 cylinder race car before I added the accusump, I used to run only a tuna can (along with the front cooler and large oil pump) a high volume oil pump is probably a really good addition to help during any momentary dips in oil pressure We didn't add the accusump due to any failures but improved oiling during cornering should increase motor life and during the 13 or so years we ran the 4 cylinder race car it evolved from DE to full Club Race.... we kept buying hotter and hotter more dedicated motors during that time and at some point it became a bit of insurance to improve oiling and help an expensive motor last longer. brant |
Lo-Fi Version | Time is now: 29th June 2024 - 12:34 PM |
