recent Sebring Abuse, Oil system help |
Jetsetsurfshop |
Dec 17 2013, 10:32 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
ThePaintedMan |
Dec 20 2013, 12:01 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Brant, I KNOW I've asked you this before, probably over two years ago when I first started. But is that all there is to it to add a front oil cooler for a /4? A high volume pump, sandwich adapter, lines, cooler and ducting? I admit I still don't quite get the Type 4 oiling system, but I was always worried about pressure dropping off from running oil that far forward and then back.
ChrisFoley |
Dec 20 2013, 08:55 AM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Brant, I KNOW I've asked you this before, probably over two years ago when I first started. But is that all there is to it to add a front oil cooler for a /4? A high volume pump, sandwich adapter, lines, cooler and ducting? I admit I still don't quite get the Type 4 oiling system, but I was always worried about pressure dropping off from running oil that far forward and then back. I use dash 12 lines to minimize pressure losses from drag. |
Lo-Fi Version | Time is now: 27th September 2024 - 07:58 PM |
