Starts out smooth, then what the buck? |
Jesco Reient |
Dec 18 2013, 06:24 PM
Member Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest |
When I first start the car cold for the day. (2056, D-jet, Raby 9590 cam, timing 27 advance @3500) The car has no cold start valve but has not seemed to care. First start it runs smoothly pulls away from the house shifting @ 3500 it acts nicely. After warming up for awhile as the motor reaches 3200 to 3600 it bucks severely then above 3600 it smooths out a bit. Then as it gets warmer the bucking moves down the RPM range to 2600 to 2800 RPM becoming not very drivable. any ideas out there? (IMG:style_emoticons/default/confused24.gif)
boxsterfan |
Dec 19 2013, 10:57 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Also, how about your fuel filter? Clogged?
Or a pinched fuel line up front by the gas tank? Still running original plastic fuel lines in the tunnel or upgraded to SS? And, as crazy as it may sound, how are all of your electrical grounds? Battery to body and transmission groundstrap are the biggies. |
Jesco Reient |
Dec 19 2013, 11:46 PM
Also, how about your fuel filter? Clogged? Or a pinched fuel line up front by the gas tank? Still running original plastic fuel lines in the tunnel or upgraded to SS? And, as crazy as it may sound, how are all of your electrical grounds? Battery to body and transmission groundstrap are the biggies. Thanks again for the input, Original plastic lines replaced by Stainless Steel lines at the beginning of the build, I have checked all the hoses to make sure that they are smooth with no kinking. Secured the correct groundstrap to the transmission during the engine/transmission installation. I have checked the other grounds back through the harness with a Fluke Multimeter. r_towle "What is your valve train setup? Aluminum or chromoly push rods? Swivel foot or solid adjusters? Last time you adjusted the valves?" The valve train set up is comprised of Raby's spring eliminator spacers, Swivel foot adjusters, Chromoly pushrods, and I just adjusted the valves to zero lash prior to the start up last week. the engine has run well except for the bucking since the valaves were adjusted. rick 918-S "From the sounds of your last post about going through the entire F.I. and refurbishing the vacuum hoses and electrical connections I would start to suspect fuel delivery. I wonder if the fuel pump is weak. Describe the bucking. is it a miss or a stall?" Miss could be from the spark plug wire interfering with the MAPS. Someplace around here there is some info about keeping the plug wire away from the MAPS as it will cause issues. Stall could be from weak pump." rick, It feels like a plug or plugs laying down, but I'm thinking with my lack of experience with the feel of the D-Jetronic injection an injector laying down could feel similar. I put a fuel pressure gauge on the driver's side fuel rail (a solid 30 PSI @ 3500 RPM) and started the engine and rechecked the timing this afternoon. The timing is now once again verified to be set to 27 degrees @ 3500. I added a new Yellow mark on the fan when the engine is at 0 Degrees TDC, This combined with my computerized timing light with 27 degrees of advance verified the timing was slightly off from yesterday. I am satisfied with the new timing and the car drove a good bit better with a slight stumble at 3400 to 3800 RPM. But still not something I'd hand over to my wife and so go have fun. gothspeed "The above is good advice ..... the only thing I'd add, is maybe the CHT sensor is bad or not getting a good connection." This is next on my check list, in my research today I have found that if I have the 1974 sensor in my 1973 set up it may not act correctly, I have also found out today that there is supposed to be a resistor inline on the 1973 2.0 litre D-Jet cars that I don't have inline. Brad Mayeur has told me it needs to be a 270 Ohm resistor. That and I may attempt to swap in a different distributor and see if the problem stays the same or goes away. The advice regarding the wideband A/F meter is interesting which one did you use? I can also check the resistance of the different sensors again and make sure they are still in specifications. The end result is the car was barely drivable today, so I took it for a short test drive, better than yesterday but tomorrow will be a day of rest for the little car. Thank you all for your input I'll keep you apprised of where it is at. |
r_towle |
Dec 20 2013, 10:48 AM
Custom Member Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
r_towle "What is your valve train setup? Aluminum or chromoly push rods? Swivel foot or solid adjusters? Last time you adjusted the valves?" The valve train set up is comprised of Raby's spring eliminator spacers, Swivel foot adjusters, Chromoly pushrods, and I just adjusted the valves to zero lash prior to the start up last week. the engine has run well except for the bucking since the valves were adjusted. So, there may be a clue here... just saying. My 911 did this. I fixed everything and replace alot of the vacuum, ignition etc. I adjusted the valves, problem solved. Loosen them up. They will just be louder. They will then close all the way when hot. This may fix the issue. You may need to adjust the valves more than a few times to determine the exact setup your specific motor will run correctly at. Metal is different from your motor to mine. There is no one answer that works for each motor. Search google on Chromoly push rods and valve lash adjustments. Lots of opinions, lots of research. Summary, at least my summary, is your motor is not the same as any other motor on earth. Your cylinders, heads, springs, valves, camshaft, and lifters would all produce different expansion results than any of mine. So your valve adjustment would end up being different than mine. Loosen them up, let it be loud to see if the bucking problem goes away. Then walk them back towards a zero lash slowly until you find the sweet spot for your motor. rich |
Lo-Fi Version | Time is now: 20th June 2024 - 05:24 AM |
