Jetsetsurfshop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States ![]() |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I think the fan will help too
although some say at speed the fan becomes intrusive and a partial blockage to full frontal air (if you have full frontal air) I would build a scoop on that to pull in clean air from under the car. That would add some aero drag but the trade off being enough air flow to cool better no matter what you need to add some screen to that cooler to protect it from rocks and garbage |
Jetsetsurfshop |
I think the fan will help too although some say at speed the fan becomes intrusive and a partial blockage to full frontal air (if you have full frontal air) I would build a scoop on that to pull in clean air from under the car. That would add some aero drag but the trade off being enough air flow to cool better no matter what you need to add some screen to that cooler to protect it from rocks and garbage Oil being cool is priority number 1. Want to Chump it for 14 hours (IMG:style_emoticons/default/blink.gif) A little aero drag is ok. I planned on doing a protective screen and forgot. I looked for rubber up there and there was none. Still need a screen though. (IMG:style_emoticons/default/agree.gif) Fan will be on soon too |
Lo-Fi Version | Time is now: 29th June 2024 - 12:50 PM |
