> The 1st thing to do on the 1st, It might be "long" but don't ignore it
boxsterfan
post Jan 1 2014, 08:24 PM
914's are kewl
Check your longs!! Mine had some piles of dirt come out (not necessarily picture below) but not that much. There wise a nice clod of dirt compacted around the jack point on the passenger side.
My car is, so fortunately, looking pretty good. I have rust in the hell hole. My firewall and floorboards look great. I am sure there is rust back in behind that long area though.
First is drivers side:
euro911
post Jan 2 2014, 02:13 AM
I'm going to insert an inspection camera in the longs to assess their condition and see where any obstacles exist.
I used Eastwood's 'Rust Encapsulator' spray (the green stuff) in my tunnel, will probably use the same in the longs.
I'm thinking the best place for a drain hole will be at the lowest section in each of the longs, just beyond where the downward angle transitions to horizontal (IMG:style_emoticons/default/idea.gif)
boxsterfan   The 1st thing to do on the 1st   Jan 1 2014, 08:24 PM
boxsterfan   And passenger side:   Jan 1 2014, 08:26 PM
Mike Bellis   I pulled my passenger rocker last year for the fir...   Jan 1 2014, 08:30 PM
euro911   When I pulled the rocker covers off the 'BB...   Jan 1 2014, 08:38 PM
gifted914   When I pulled the rocker covers off the 'BB...   Jan 1 2014, 08:58 PM
boxsterfan   Hmmmm......that seems like a good idea to drill so...   Jan 1 2014, 09:12 PM
gifted914   Hmmmm......that seems like a good idea to drill s...   Jan 2 2014, 12:49 AM
euro911   I'm going to insert an inspection camera in th...   Jan 2 2014, 02:13 AM
cary   The rocker panel has drains pressed in it already ...   Jan 2 2014, 08:05 AM
ThePaintedMan   :agree: When I did my long repair, I made sure t...   Jan 2 2014, 08:15 AM
rhodyguy   with that amount pictured i think you're in pr...   Jan 2 2014, 09:14 AM
boxsterfan   Thanks for all of the replies. I am going to clean...   Jan 2 2014, 11:05 AM
gifted914   Thanks for all of the replies. I am going to clea...   Jan 2 2014, 01:40 PM
boxsterfan   Thanks for the all the replies. Who sells the Roc...   Jan 2 2014, 02:00 PM
euro911   Once you spray an 'encapsulator', why woul...   Jan 2 2014, 03:02 PM
boxsterfan   Once you spray an 'encapsulator', why wou...   Jan 2 2014, 03:54 PM
nsyr   After the rust is treated, flood the inside of the...   Jan 2 2014, 05:06 PM
cary   Here's a picture of the rocker laying on the b...   Jan 2 2014, 10:16 PM
boxsterfan   So I was able to finish cleaning up the longs toda...   Jan 4 2014, 10:21 PM
euro911   Doesn't look bad at all. Maybe wire-brush the...   Jan 4 2014, 11:14 PM
boxsterfan   Yeah, those rubber plugs would be good to know if ...   Jan 5 2014, 12:49 AM
boxstr   If you look inside the engine compartment back up...   Jan 5 2014, 03:17 PM
boxstr   If you look inside the engine compartment back up...   Jan 5 2014, 03:44 PM
euro911   Thanks, Craig ... I'll check it out and see if...   Jan 5 2014, 05:08 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 08:09 PM
