rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i need some pictures of your stock install in the engine compartment as a reference. canister and which way the hoses and small line run. thanks.
k |
gcrotvik |
Member ![]() ![]() Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest ![]() |
Hey Kevin,
They moved the canister from the front trunk to the engine compartment sometime after the 11/73 builds. In later 74's it was located as shown in the first 2 pictures below. In 75-76 years (3rd picture), it was moved again to the battery tray. This is the same setup for 1.8's and 2.0's If you are looking for routing of hoses and hose sizes, look on Jeff Bowlsby's site. He has just about everything you will need there. Here is the link: https://bowlsby.net/914/Classic/TechNotebook.htm If you need the bracket, check with Bruce Stone. Hope this helps. Greg Attached image(s) ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 08:38 AM |
