> Another 914 goes under the knife, UPDATE: IT'S ALIVE....FINALLY
vintage914racer
post Dec 8 2013, 12:36 AM
Today was a chilling day, both figuratively and literally. You see, I dropped off my 1970 914-6 for some long overdue structural repairs in Northern Minnesota. It was both freakishly cold and a milestone in my 914 ownership.
A little backstory....
Since I was was a kid cars have been a part of my life, particularly 914s. In the early 1980's my father, who was in his early 30's, was diagnosed with cancer and endured months of experimental treatment at the U of M. Miraculously he overcame the odds and entered remission. Upon paying back his medical bills he celebrated by purchase a 1970 914-6.
This particular car brings back many fond memories from my childhood. I remember riding in between my parents in the front seat, urging my dad to go faster. I remember riding in the car as we drove up to Brainerd International Raceway to watch the IMSA Camel GT series run. I remember my school age friends looking at the speedometer in awe, simply blown away that it went up to 180mph. As a kid I affectionately referred to the car as "Speedy."
Long story short, the car fell into my possession many years later following my father's passing and would become a reminder of the great times I spent with him. The car spent the majority of the last 20-years languishing in our garage. It was brought back to life mechanically, but had a number of battle wounds that accumulated both by me as a lackadaisical kid and from corrosion on the non-galvanized body. Knowing that a car does not do wel sitting, I enthusiastically drove it whenever I could. In fact the last couple years I had it on the road I probably average 3k miles per year, which is a lot for a sports car in Minnesota where it snows 6 months out of the year...more on this later.
Deep down I knew that the car suffered from corrosion and I finally faced it head on when I removed the rocker covers just over a year ago. I soon discovered that the car suffered in the usual rust areas. So much that I was no longer comfortable driving it. The passenger side needed an inner and outer long. The drivers side needed an outer panel. I found that the rear half of the floorpan required replacement. Surprisingly, the hell hole was in pretty decent shape.
Despite having some little welding experience under my belt I knew the repairs weren't in my wheelhouse. After consulting the 914world brain trust I quickly learned that that the solution to my problems was just a couple hour drive away. Rick, aka Rick918S, has torn apart a number of 914s and after some back and forth he agreed to tackle the project.
Before hauling the car up north, I pulled the engine and interior. Upon pulling the engine I learned that the car no longer has it's original motor, rather is has one from a 68s. For the record the engine is stamped with 901/02 and serial number 4080519. Makes sense since the car seemed to have more zip than 110hp brings. Once stripped of the engine I loaded it up on my trailer in anticipation of the pilgrimage north.
So, this morning at the crack of dawn I hopped in my truck and made the 2.5 hour trip to Duluth, MN, with the car. Normally a trip to Duluth isn't a big deal, however the weather made it a bit more exciting. Earlier this week we got dumped on by snow. In the Minneapolis metro we got about 8-inches. Duluth got closer to 18-inches. If the snow along wasn't enough, the temperature brought things to a new level. When I left my house in Minneapolis the temperature read -7 degrees. As I got closer to Duluth the thermometer dropped to -19F. Soon thereafter it dropped to -26.
Part of me thought the car would break down and I would become a human popsicle. With inconsistently plowed roads part of me also thought I would careen off the road, but with a stroke of luck I made it to Duluth in one piece.
Rick and I unloaded the car quickly in an effort to escape the cold and rolled the car into his shop.
At present the car sits in good company next to a 1960s Mercedes roadster. Whereas the 914 normally hibernates during winters, this year it will partake in a makeover program. The aforementioned structural elements will get repaired. Concurrently I will be putting the engine on a stand to adjust the valves and replacing gaskets and seals as needed. I'll open the transmission to make sure everything looks good. I plan to replace the sail panel vinyl, carpet, shocks and rechrome the rear bumper. Inevitably, the slop will get more slippery. The goal is to have a stong structural and mechanical foundation come spring. Once complete, I'll drive the car for a few years before tackling the superficial cosmetic blemishes.
Stay tuned for a photo diary of the progress.
rick 918-S
post Jan 7 2014, 09:34 PM
Hey nice rack! -Celette
Great bunch of guys up there in the Great White North! I called R.D. and left Mike a voicemail and then sent an email with a question about their online catalog. I thought that's odd they didn't call back... (IMG:style_emoticons/default/confused24.gif) Then it dawned on me. It was Sunday (IMG:style_emoticons/default/screwy.gif) Duh. (IMG:style_emoticons/default/wacko.gif)
Ya I found a little more rust. I called R.D. to see if they had a short rail section as there is no need to get nuts and cut out the entire rail. I will just do a short patch at the jack point and it will be fine. I'm actually really happy with the floor condition. After the removal of the tar boards there was very little more rust than was showing. There is an odd rust hole at the front of the right foot well with no real reason for it. Very easy fix though. I have a cali front floor section that will fit it right up. I removed the home made battery tray and broken hinge.
There should be some real progress by the end of the week.
ThePaintedMan
post Jan 8 2014, 09:30 PM
QUOTE(rick 918-S @ Jan 7 2014, 10:34 PM) *
Hey Rick, I had very similar rust in the same spot on mine. I assumed it was because of the foam block that sat in the passenger footwell, soaking up water, but the /6s had the removable "dogbone" footrest, correct?
Beautiful car - can't wait to see the work and the eventual video!
vintage914racer   Another 914 goes under the knife   Dec 8 2013, 12:36 AM
speed metal army   :wttc: :)   Dec 8 2013, 12:46 AM
Jeff Bowlsby   Whats that white stuff? ' Rick is a master, ...   Dec 8 2013, 12:49 AM
euro911   http://www.914world.com/bbs2/uploads/post-1473-138...   Dec 8 2013, 12:55 AM
gothspeed   Nice story. Nice photo too :thumbsup: You...   Dec 8 2013, 02:11 AM
carr914   It's in Good hands with Rick!   Dec 8 2013, 06:09 AM
billh1963   Beautiful car!   Dec 8 2013, 06:10 AM
JawjaPorsche   So great the 914 stays in the family. Keep us pos...   Dec 8 2013, 06:24 AM
arcadeforever   thats a great story and thats one incredible car, ...   Dec 8 2013, 07:20 AM
bulitt   -26 Brrrrrrrrrrrrrrrrrr :blink:   Dec 8 2013, 07:43 AM
rick 918-S   This is a great story. But not just a story. Once ...   Dec 8 2013, 09:12 AM
Cairo94507   I just love the story and the fact that Ben has en...   Dec 8 2013, 10:03 AM
vintage914racer   I am very thankful that Rick decided to take on th...   Dec 8 2013, 10:11 AM
euro911   That's cool, having all the service records. ...   Dec 8 2013, 03:55 PM
Krieger   Very nice story. I look forward to the video and ...   Dec 8 2013, 07:02 PM
SirAndy   Always loved that color, it just looks right on a ...   Dec 8 2013, 07:45 PM
porbmw   Nice car! Great story! Hope my son takes c...   Dec 9 2013, 12:49 AM
gothspeed   :bump: for hopefully more pics of this -6 ... :)   Dec 10 2013, 12:53 AM
smj   I always thought cookie cutters would look good on...   Dec 10 2013, 05:57 PM
rgalla9146   I always thought cookie cutters would look good o...   Jan 8 2014, 09:50 PM
vintage914racer   Thanks, everyone, for the kind words. Since a cou...   Dec 10 2013, 09:10 PM
rick 918-S   I did a little forensics tonight. Ben's car is...   Dec 10 2013, 11:30 PM
gryphon68   Are those 15x7 Cookie Cutters? Thanks,   Dec 12 2013, 11:28 AM
vintage914racer   Are those 15x7 Cookie Cutters? Thanks, I belie...   Dec 12 2013, 12:05 PM
jfort   I, too, am looking forward to following this threa...   Dec 13 2013, 11:28 AM
krazykonrad   Rick's got mad skills, yo! You will be ama...   Dec 13 2013, 10:58 PM
rick 918-S   Slow start fellas. I'm trying to get the Merce...   Dec 13 2013, 11:17 PM
Cairo94507   Hi Rick: What does it typically cost to e-coat a c...   Dec 14 2013, 07:45 AM
rick 918-S   Hi Rick: What does it typically cost to e-coat a ...   Dec 14 2013, 08:30 AM
gothspeed   Great pics of the -6 ...... :beer2:   Dec 14 2013, 06:41 PM
Big Len   Love this color and the car. Good luck with the re...   Dec 14 2013, 06:55 PM
Cairo94507   Please post pictures of the process if you can and...   Dec 15 2013, 11:15 AM
rick 918-S   Please post pictures of the process if you can an...   Dec 15 2013, 11:20 AM
vintage914racer   Rick has been plugging away on the car and just se...   Jan 7 2014, 08:34 PM
rick 918-S   Great bunch of guys up there in the Great White No...   Jan 7 2014, 09:34 PM
ThePaintedMan   There is an odd rust hole at the front of the ri...   Jan 8 2014, 09:30 PM
Eric_Shea   ***subscribed*** Is it done yet Rick? :D   Jan 8 2014, 02:42 PM
lanker88   Can't wait to see the progress!!! ...   Jan 8 2014, 03:32 PM
porbmw   Love the colour (that's colour...not color, fo...   Jan 8 2014, 05:36 PM
rick 918-S   I'm building a jack so I can get it up on my n...   Jan 8 2014, 09:25 PM
vintage914racer   The rust removal continues. Rick is working away ...   Jan 22 2014, 05:59 PM
vintage914racer   While Rick has been working on the body, I've ...   Jan 22 2014, 06:04 PM
rick 918-S   Nice work Ben. I'm just closing up the hell ho...   Jan 22 2014, 07:53 PM
bigkensteele   Incredible work, Rick!   Jan 22 2014, 09:23 PM
rick 918-S   Top of the rail closed in. There is an inner panel...   Jan 22 2014, 11:43 PM
Socalandy   All the usual rust spots :( and another cool thr...   Jan 23 2014, 11:11 AM
doug_b_928   Looks great, Rick! What kind of primer did yo...   Jan 23 2014, 09:15 PM
rick 918-S   Looks great, Rick! What kind of primer did y...   Jan 23 2014, 09:37 PM
rick 918-S   Blew up the compressor tonight! Drats! I h...   Jan 23 2014, 09:57 PM
sixnotfour   Thank god the Mercedes is gone , you're rippin...   Jan 23 2014, 10:17 PM
rick 918-S   Thank god the Mercedes is gone , you're rippi...   Jan 23 2014, 10:30 PM
vintage914racer   It looks like its really coming along ow   Jan 23 2014, 11:27 PM
1972 914 2.0   I've always wanted to see a 914 on cookie cutt...   Jan 25 2014, 09:03 PM
rick 918-S   Sux with no compressor! Pump won't be here...   Jan 25 2014, 10:29 PM
Bartlett 914   Hi Rick I will be working on door gap issues on a...   Jan 28 2014, 08:42 AM
rick 918-S   By supporting the car under the suspension you are...   Jan 28 2014, 09:06 AM
vintage914racer   By supporting the car under the suspension you ar...   Jan 28 2014, 01:24 PM
rick 918-S   The compressor is back up and running. I installe...   Jan 28 2014, 06:00 PM
rick 918-S   Lower bulkhead engine side repaired.   Jan 28 2014, 10:10 PM
r_towle   While you have the floor off, could you please tak...   Jan 28 2014, 10:19 PM
rick 918-S   While you have the floor off, could you please ta...   Jan 29 2014, 03:09 PM
rick 918-S   I started welding in the floor pan on the passenge...   Jan 29 2014, 03:14 PM
rick 918-S   Welding in the right side floor pan.   Jan 30 2014, 05:29 PM
rick 918-S   Here are a couple photos of the sill supports. The...   Jan 31 2014, 03:28 PM
rick 918-S   Couple more photos. I installed the sill brackets ...   Jan 31 2014, 07:29 PM
vintage914racer   Couple more photos. I installed the sill brackets...   Feb 1 2014, 11:21 AM
rick 918-S   I will be closing up the right side long tomorrow ...   Feb 1 2014, 11:23 PM
KELTY360   Nice work! You sure are getting your money...   Feb 2 2014, 12:16 AM
rick 918-S   Nice work! You sure are getting your money...   Feb 2 2014, 09:11 AM
r_towle   Quickly.... The floor pan welds over (under reall...   Feb 2 2014, 09:26 AM
rick 918-S   Quickly.... The floor pan welds over (under real...   Feb 2 2014, 10:02 AM
rick 918-S   Finally closing up the right long. I sleeve all th...   Feb 3 2014, 10:04 PM
doug_b_928   Nice work, Rick! I hope you're still maki...   Feb 3 2014, 10:52 PM
rick 918-S   Nice work, Rick! I hope you're still mak...   Feb 3 2014, 11:02 PM
r_towle   Nice work, Rick! I hope you're still ma...   Feb 3 2014, 11:06 PM
rick 918-S   [quote name='rick 918-S' post='1993001' date...   Feb 3 2014, 11:15 PM
cary   That's a nice car ............ Wow.   Feb 3 2014, 11:15 PM
r_towle   No we....just me. Boy went missing again...seems t...   Feb 3 2014, 11:16 PM
pete000   Impressive metal work !!!! :welde...   Feb 3 2014, 11:21 PM
sixnotfour   There is a new inner long for the right and left b...   Feb 4 2014, 05:34 AM
rick 918-S   That is a nice piece! Who carries those?   Feb 4 2014, 08:29 AM
Luke M   Great work on the repairs Rick. I have the same ru...   Feb 4 2014, 08:57 AM
rick 918-S   Great work on the repairs Rick. I have the same r...   Feb 4 2014, 09:26 AM
bigkensteele   I hope you remembered to re-install the heater tub...   Feb 4 2014, 07:29 PM
sixnotfour   I hope you remembered to re-install the heater tu...   Feb 4 2014, 07:35 PM
rick 918-S   I hope you remembered to re-install the heater tu...   Feb 4 2014, 09:18 PM
euro911   I hope you remembered to re-install the heater tub...   Feb 4 2014, 10:52 PM
rick 918-S   [quote name='rick 918-S' post='1993496' date...   Feb 4 2014, 10:56 PM
rick 918-S   Not much progress today. I spent most of the day c...   Feb 4 2014, 10:42 PM
rick 918-S   I spot welded the outer long today. I used a pinch...   Feb 6 2014, 12:17 AM
Cairo94507   That is beautiful work. :welder:   Feb 6 2014, 07:10 AM
rick 918-S   I wasn't happy with the restoration design pan...   Feb 6 2014, 08:09 PM
vintage914racer   Can't wait to see the car in person tomorrow.   Feb 6 2014, 10:01 PM
r_towle   :blink: :shades2:   Feb 6 2014, 10:13 PM
CptTripps   Nicely done sir...   Feb 7 2014, 07:49 AM
rick 918-S   Not much progress. I closed in the firewall this w...   Feb 16 2014, 08:28 AM
euro911   Quit buying Harbor Freight S#IT tools :poke:   Feb 16 2014, 01:15 PM
rick 918-S   Quit buying Harbor Freight S#IT tools :poke: No...   Feb 16 2014, 04:50 PM
rick 918-S   Finished up the engine bay including the rear lid ...   Feb 23 2014, 06:39 PM
sixnotfour   NICE ..   Feb 23 2014, 06:43 PM
32 User(s) are reading this topic (32 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 10:33 PM
