engine bay charcoal canister, 74' pictures needed |
rhodyguy |
Jan 3 2014, 02:25 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i need some pictures of your stock install in the engine compartment as a reference. canister and which way the hoses and small line run. thanks.
k |
rhodyguy |
Jan 9 2014, 08:10 AM
jeff's site was very helpful. found a canister and mounting strap. located the small line that runs from the fuel tank to the canister. its rather long and was found on the rear area of the engine which leads me to think the canister was not battery tray mounted. is the strap mount type specific for the locations or the same for both? i have a box of ljet stuff and the strap mount may be in there. i'm not sure what the correct one looks like and exactly how/where it bolts on. could use a picture of the correct rear strap and one of how it's installed. getting closer….
boxsterfan |
Jan 9 2014, 11:12 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
jeff's site was very helpful. found a canister and mounting strap. located the small line that runs from the fuel tank to the canister. its rather long and was found on the rear area of the engine which leads me to think the canister was not battery tray mounted. is the strap mount type specific for the locations or the same for both? i have a box of ljet stuff and the strap mount may be in there. i'm not sure what the correct one looks like and exactly how/where it bolts on. could use a picture of the correct rear strap and one of how it's installed. getting closer…. Where you able to find a new cannister or did you just find one in good shape? I've been thinking of taking my early 1974 cannister out and replenishing with charcoal but not sure if it can even be taken apart. Made of plastic I believe. |
saigon71 |
Jan 10 2014, 08:19 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
jeff's site was very helpful. found a canister and mounting strap. located the small line that runs from the fuel tank to the canister. its rather long and was found on the rear area of the engine which leads me to think the canister was not battery tray mounted. is the strap mount type specific for the locations or the same for both? i have a box of ljet stuff and the strap mount may be in there. i'm not sure what the correct one looks like and exactly how/where it bolts on. could use a picture of the correct rear strap and one of how it's installed. getting closer…. Where you able to find a new cannister or did you just find one in good shape? I've been thinking of taking my early 1974 cannister out and replenishing with charcoal but not sure if it can even be taken apart. Made of plastic I believe. I just replaced the activated charcoal in my 1974 canister. The top pops off with a screwdriver and some gentle prying. Easy job by 914 standards. You will need 1.7 lbs of activated charcoal. No more gas fumes in the cabin! |
Lo-Fi Version | Time is now: 26th June 2024 - 07:39 AM |
