> Steel fuel lines through center tunnel question
Demick
post Jul 27 2004, 08:28 PM
Ernie made me do it!
I'll be taking advantage of my engine being out to move my fuel pump to the front and run steel fuel lines through the center tunnel. I know many of you have done this. I just have one question:
Regarding the ~30 degree bend that happens near the front firewall to go through the front gromet: can I put this bend in the tube first and then insert it all the way through the rear firewall and up to the front? Or do I need to somehow add that bend with the tube already in place (maybe insert it too far so that I can make the bend in the fuel tank area and then pull the tube back to it's proper place). I thought I remembered making the bend first, but it seems like it would be awfully hard to get it through the center tunnel with the tube already bent.
Just wondering what the easiest way is.
Thanks
Demick
Demick
post Aug 1 2004, 07:50 PM
I just got done installing the steel fuel lines and moving the fuel pump to the front. Damn. What a major pain that was. One of the least fun jobs I've ever done on that car, and I've done some pretty un-fun projects.
Everything I did seemed like 2 steps forward, one step back.
Thanks for the tips guys. They definitely helped. I have a new tip to add. If you are using flare fittings, make sure the flare nut is on the right end before bending any tubes. Twice I forgot to get the nut in the right place and had to scrap the tube after bending. That sucked.
Demick
- Lo-Fi Version Time is now: 15th January 2025 - 04:06 AM
