porschefile2010 |
Member ![]() ![]() Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand ![]() |
Just pulled the plugs after 1500 miles on a rebuild and they are all evenly black. Can I adjust the screw on the control unit to lean it up a bit and if so which way and by how much? Thanks once again. Richard
boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
Have you looked at your Air Flow Sensor? Timing, dwell and spark plug gap?
How about your fuel injectors? Are they spraying a fine mist? Here is a link to troubleshooting L-Jet systems from Bowlsby's site. Note: this is for a 912E (same motor...type IV 2.0L.) https://bowlsby.net/914/Classic/zTN_Man08.pdf |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Have you looked at your Air Flow Sensor? Timing, dwell and spark plug gap? How about your fuel injectors? Are they spraying a fine mist? Here is a link to troubleshooting L-Jet systems from Bowlsby's site. Note: this is for a 912E (same motor...type IV 2.0L.) https://bowlsby.net/914/Classic/zTN_Man08.pdf Not gonna help a D-jet owner all that much .................. The Cap'n |
boxsterfan |
Lo-Fi Version | Time is now: 20th June 2024 - 05:58 AM |
