Jesco Reient |
Member ![]() ![]() Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest ![]() |
When I first start the car cold for the day. (2056, D-jet, Raby 9590 cam, timing 27 advance @3500) The car has no cold start valve but has not seemed to care. First start it runs smoothly pulls away from the house shifting @ 3500 it acts nicely. After warming up for awhile as the motor reaches 3200 to 3600 it bucks severely then above 3600 it smooths out a bit. Then as it gets warmer the bucking moves down the RPM range to 2600 to 2800 RPM becoming not very drivable. any ideas out there? (IMG:style_emoticons/default/confused24.gif)
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,326 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I had bucking sometimes and a perfect running engine other times. I changed the coil on mine and the bucking went away. I had tried all the other suggestions. Just a thought.
Once you get it fixed you will be glad you did not switch to carbs. |
Jesco Reient |
I had bucking sometimes and a perfect running engine other times. I changed the coil on mine and the bucking went away. I had tried all the other suggestions. Just a thought. Once you get it fixed you will be glad you did not switch to carbs. The coil has been nagging at my mind since that is the only part NOT replaced during the rebuild, I just have not gone there yet. The TPS is set again by the ohm-meter method, and the resistance readings on the MPS were right on the numbers. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:27 AM |
