> How To - 914 Adjustable Rear Coil Overs, Specifically for Bilstein shocks
tomeric914
post Jan 25 2014, 11:14 PM
One Lap of America in a 914!
I was looking for details on the interwebs on coil overs with helper springs in particular for the Porsche 914 and found not much at all. There was something pretty close on an Audi forum, but not close enough. I was looking for a cost effective coil over setup that works and found http://shop.a1racing.com who had everything I needed at a decent price.
Zero rate helper spring keep the main spring pressed against its perches when jacking up the vehicle or any time the suspension is fully extended. These helpers are usually needed when running a spring rate higher than 150 pounds (in a 914), otherwise the back end of the car will be too high.
Below is a parts list, visual parts list, and video of how it all goes together. The part numbers listed are specific to A-1 Racing's website.
This is one of many ways to get to an easily adjustable suspension setup. Main spring rate will depend on your driving style and intentions for your car.
Note that part numbers BRP597 and 12460 have been modified slightly to allow for full compression of the helper spring. If not modified, the floater will contact the adjusting nut before the helper spring is fully compressed causing all of the force from the main spring to press against the thin aluminum coupler. The coupler will fail.
The floater / coupler does go on the bottom. Otherwise, the helper and main spring will have no lateral support.
As with any modification, proceed with caution. If you don't know what you're doing, STOP and find someone who does. (IMG:style_emoticons/default/bye1.gif)
Parts List:
12456 - Threaded Coil Over Sleeve 7" (qty 2)
12460 - 2-1/2" Coil Over Adjusting Nut (qty 2)
12470 - 2-1/2" Non-Slotted Coil Over Top Hat (qty 2)
BRP597 - Coil Over Spring Floater / Coupler (qty 2)
PROZ902 - Coil Over Adjustment Wrench (qty 1)
HYPCS100 - Hypercoil Zero Rate Helper Spring (qty 2)
HYP1810B - Hypercoil Main Spring (qty 2) - you must select the spring load
https://www.youtube.com/watch?v=SGIrZ1sJVdc
kid914
post Jan 26 2014, 11:00 AM
ALWAYS lead...NEVER follow!!!!
Can you post pics of them installed?
I would love to see the stance before I order.
Thanks for the nice write-up and lists with part#'s and video, along with the web site info. (IMG:style_emoticons/default/beerchug.gif)
(IMG:style_emoticons/default/first.gif)
tomeric914   How To - 914 Adjustable Rear Coil Overs   Jan 25 2014, 11:14 PM
mrbubblehead   awsome. i added up all the parts and it came out t...   Jan 26 2014, 12:17 AM
tomeric914   ...what about the fronts???? :popcorn: The front...   Jan 26 2014, 07:18 AM
mrbubblehead   735 bucks at elephant.   Jan 26 2014, 12:23 AM
Starlack   Hello and good day I'm interested in the Coil ...   Jan 26 2014, 12:45 AM
Woody   Check out Rebel Racing. That's where I bought ...   Jan 26 2014, 06:56 AM
Cupomeat   Nicely done Tom! Thanks   Jan 26 2014, 10:12 AM
kid914   Can you post pics of them installed? I would love...   Jan 26 2014, 11:00 AM
tomeric914   I would love to see the stance before I order. Y...   Jan 26 2014, 11:18 AM
Starlack   Hello I read here in the springs, the designation ...   Jan 26 2014, 11:52 AM
Harpo   About 63.5mm = 6.35cm   Jan 26 2014, 12:36 PM
Starlack   About 63.5mm = 6.35cm Thank you. Ok so the 2-1...   Jan 26 2014, 12:52 PM
mrbubblehead   About 63.5mm = 6.35cm Thank you. Ok so the 2-...   Jan 26 2014, 01:43 PM
tomeric914   A couple of other details: - The top hat center h...   Jan 26 2014, 02:41 PM
3d914   Excellent job Tom, thanks for all the details. Th...   Jan 26 2014, 04:37 PM
tomeric914   Which Bilsteins are you using and what drove your...   Jan 26 2014, 07:26 PM
kid914   Would you be able to post pics of the stance? :fir...   Feb 10 2014, 09:01 PM
tomeric914   Would you be able to post pics of the stance? :fi...   Feb 10 2014, 09:13 PM
Mark Henry   Six years old but a good how to, the vid and DYI i...   Jan 16 2020, 04:52 PM
CptTripps   Bumping an old topic, but does anyone have experie...   Mar 29 2021, 06:40 AM
mlindner   I went with Ground Control, great product for 914s...   Mar 29 2021, 06:56 AM
- Lo-Fi Version Time is now: 18th December 2024 - 06:55 PM
