Adjustable Temp Electric Fans, Need help finding a sensor--page 2 |
computers4kids |
Jan 28 2014, 09:11 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Currently I have dual electric fans, each on their own relay, that both come on around 180 degrees. I would like to reduce the fan noise from both fans coming on at once since my system stays cool easily and both fans tend to be overkill. I was thinking about having one fan come on around 180 degrees and the other come on if the temperature raises 10 degrees or so above. Fans 1 and 2 would also shut themselves off once each one dips 10 degrees below their set temps.
I see Jegs sells a kit that appears to do just this for around $150 that would control both fans. http://www.jegs.com/i/Derale/259/16789/10002/-1 Another possibility, would be to let Fan 1 continue to come on at 180 using the temp sender Renegade supplied, disconnecting the Fan 2. Jegs also sells the same adjustable unit for a single fan for $83. I would connect Fan 2 using the single controller for half the price. http://www.jegs.com/i/Derale/259/16779/10002/-1 What are your thoughts? |
r_towle |
Jan 28 2014, 09:20 PM
Custom Member Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Look at the 944 setup.....junkyard maybe.
I believe it's a two stage fan setup at two temps. |
Lo-Fi Version | Time is now: 29th January 2025 - 11:13 PM |
