> Adjustable Temp Electric Fans, Need help finding a sensor--page 2
computers4kids
post Jan 28 2014, 09:11 PM
Love these little cars!
Currently I have dual electric fans, each on their own relay, that both come on around 180 degrees. I would like to reduce the fan noise from both fans coming on at once since my system stays cool easily and both fans tend to be overkill. I was thinking about having one fan come on around 180 degrees and the other come on if the temperature raises 10 degrees or so above. Fans 1 and 2 would also shut themselves off once each one dips 10 degrees below their set temps.
I see Jegs sells a kit that appears to do just this for around $150 that would control both fans. http://www.jegs.com/i/Derale/259/16789/10002/-1
Another possibility, would be to let Fan 1 continue to come on at 180 using the temp sender Renegade supplied, disconnecting the Fan 2. Jegs also sells the same adjustable unit for a single fan for $83. I would connect Fan 2 using the single controller for half the price. http://www.jegs.com/i/Derale/259/16779/10002/-1
What are your thoughts?
computers4kids
post Jan 28 2014, 10:27 PM
Just read BigKat's setup. Since I have two single speed fans, I like how he turns on both at 1/2 speed and then, only if, the temp rises to 190 then they kick on at full speed. All with three relays.
Question. Looking at his diagram, would the two different sensors represent the ECU pins (C1, C2) if I'm using standard sensors at not a ECU to trigger the fans?
Does it matter where the sensors are mounted?
post Jan 29 2014, 09:28 AM
QUOTE(computers4kids @ Jan 28 2014, 08:27 PM) *
Correct on the c1/c2 pins. I would think that any N/O temp sensor(s) would work. Just need the circuit(s) to close to ground instead of 12v. That and the added relay would work. I don't know what your power plant is but I suspect you would want the sensors located close to the block.
andys
post Jan 29 2014, 11:08 AM
QUOTE(76-914 @ Jan 29 2014, 07:28 AM) *
I too don't see any reason why BIGKAT83's setup wouldn't work with two separate sensors. I have the same setup on mine that's run by the LS1 PCM. The slow speed fans (1/2 speed) are very quiet indeed.
Andys
computers4kids   Adjustable Temp Electric Fans   Jan 28 2014, 09:11 PM
r_towle   Look at the 944 setup.....junkyard maybe. I believ...   Jan 28 2014, 09:20 PM
76-914   Can you switch with ground? If so (and courtesy of...   Jan 28 2014, 09:24 PM
Bruce Hinds   An easy way is to use two sensors. Use one for in...   Jan 28 2014, 09:54 PM
jimkelly   cheaper would be to install a second temp sensor f...   Jan 28 2014, 09:57 PM
computers4kids   Two sensors sound like a super simple way to accom...   Jan 28 2014, 10:06 PM
computers4kids   Just read BigKat's setup. Since I have two si...   Jan 28 2014, 10:27 PM
76-914   Just read BigKat's setup. Since I have two s...   Jan 29 2014, 09:28 AM
andys   Just read BigKat's setup. Since I have two ...   Jan 29 2014, 11:08 AM
jcd914   You could use something like the Audi/VW/Porsche 9...   Jan 28 2014, 11:13 PM
Bartlett 914   I would not use a sensor on the input. Only on the...   Jan 29 2014, 11:20 AM
mikesmith   I recently installed a Painless F5 controller for ...   Jan 29 2014, 03:30 PM
76-914   I recently installed a Painless F5 controller for...   Jan 29 2014, 04:24 PM
mikesmith   The PWM isn't entirely smooth, so now at a s...   Jan 29 2014, 05:03 PM
76-914   [quote name='76-914' post='1990279' date='Ja...   Jan 29 2014, 08:45 PM
stugray   Put both fans in series. They should run at half s...   Jan 29 2014, 06:15 PM
r_towle   oh DUH.... My Eurovan has this. Look for the temp...   Jan 29 2014, 06:25 PM
andys   The circuit logic in BIGCAT83's schematic (how...   Jan 29 2014, 07:36 PM
computers4kids   Lots of great information. OK. I'll run two ...   Jan 29 2014, 09:07 PM
Andyrew   When I had my overheating problems (and still do.....   Jan 29 2014, 10:40 PM
jimkelly   c1 and c2 represent sensors that when active creat...   Jan 30 2014, 07:17 AM
76-914   Yes, c1 & c2 are grounds which when are contro...   Jan 30 2014, 09:06 AM
jimkelly   thanks : ) back to graphic.   Jan 30 2014, 09:22 AM
computers4kids   I went ahead and totally rewired my dual electric ...   Feb 1 2014, 08:15 PM
Mike Bellis   Any ideas how to source a 200 degree sensor that ...   Feb 1 2014, 09:32 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 29th January 2025 - 11:05 PM
