Adjustable Temp Electric Fans, Need help finding a sensor--page 2 |
computers4kids |
Jan 28 2014, 09:11 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Currently I have dual electric fans, each on their own relay, that both come on around 180 degrees. I would like to reduce the fan noise from both fans coming on at once since my system stays cool easily and both fans tend to be overkill. I was thinking about having one fan come on around 180 degrees and the other come on if the temperature raises 10 degrees or so above. Fans 1 and 2 would also shut themselves off once each one dips 10 degrees below their set temps.
I see Jegs sells a kit that appears to do just this for around $150 that would control both fans. http://www.jegs.com/i/Derale/259/16789/10002/-1 Another possibility, would be to let Fan 1 continue to come on at 180 using the temp sender Renegade supplied, disconnecting the Fan 2. Jegs also sells the same adjustable unit for a single fan for $83. I would connect Fan 2 using the single controller for half the price. http://www.jegs.com/i/Derale/259/16779/10002/-1 What are your thoughts? |
mikesmith |
Jan 29 2014, 03:30 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
I recently installed a Painless F5 controller for the Renegade setup for basically the same reason; when those fans come on, you feel like you're driving a hovercraft (plus, the lights dim something fearsome).
Apart from having to make an adapter for the sensor in the radiator it went smoothly and the result is a big improvement, although even at 50% the fans are still fairly noisy. The PWM isn't entirely smooth, so now at a stoplight at night with the fans running the headlights flicker a little, but overall temperatures haven't been cycling up and down like they used to - it gets to around 180 and then just stays there. |
Lo-Fi Version | Time is now: 29th January 2025 - 11:01 PM |
