> Adjustable Temp Electric Fans, Need help finding a sensor--page 2
computers4kids
post Jan 28 2014, 09:11 PM
Love these little cars!
Currently I have dual electric fans, each on their own relay, that both come on around 180 degrees. I would like to reduce the fan noise from both fans coming on at once since my system stays cool easily and both fans tend to be overkill. I was thinking about having one fan come on around 180 degrees and the other come on if the temperature raises 10 degrees or so above. Fans 1 and 2 would also shut themselves off once each one dips 10 degrees below their set temps.
I see Jegs sells a kit that appears to do just this for around $150 that would control both fans. http://www.jegs.com/i/Derale/259/16789/10002/-1
Another possibility, would be to let Fan 1 continue to come on at 180 using the temp sender Renegade supplied, disconnecting the Fan 2. Jegs also sells the same adjustable unit for a single fan for $83. I would connect Fan 2 using the single controller for half the price. http://www.jegs.com/i/Derale/259/16779/10002/-1
What are your thoughts?
andys
post Jan 29 2014, 07:36 PM
The circuit logic in BIGCAT83's schematic (how GM designed it) switches from series (low speed) to parallel (high speed; each fan now sees 12V). The LS1 PCM also turns those fans off when the vehicle exceeds 40 MPH. Mine utilizes this feature, since I added a VSS to the axle CV.
Andys
computers4kids   Adjustable Temp Electric Fans   Jan 28 2014, 09:11 PM
r_towle   Look at the 944 setup.....junkyard maybe. I believ...   Jan 28 2014, 09:20 PM
76-914   Can you switch with ground? If so (and courtesy of...   Jan 28 2014, 09:24 PM
Bruce Hinds   An easy way is to use two sensors. Use one for in...   Jan 28 2014, 09:54 PM
jimkelly   cheaper would be to install a second temp sensor f...   Jan 28 2014, 09:57 PM
computers4kids   Two sensors sound like a super simple way to accom...   Jan 28 2014, 10:06 PM
computers4kids   Just read BigKat's setup. Since I have two si...   Jan 28 2014, 10:27 PM
76-914   Just read BigKat's setup. Since I have two s...   Jan 29 2014, 09:28 AM
andys   Just read BigKat's setup. Since I have two ...   Jan 29 2014, 11:08 AM
jcd914   You could use something like the Audi/VW/Porsche 9...   Jan 28 2014, 11:13 PM
Bartlett 914   I would not use a sensor on the input. Only on the...   Jan 29 2014, 11:20 AM
mikesmith   I recently installed a Painless F5 controller for ...   Jan 29 2014, 03:30 PM
76-914   I recently installed a Painless F5 controller for...   Jan 29 2014, 04:24 PM
mikesmith   The PWM isn't entirely smooth, so now at a s...   Jan 29 2014, 05:03 PM
76-914   [quote name='76-914' post='1990279' date='Ja...   Jan 29 2014, 08:45 PM
stugray   Put both fans in series. They should run at half s...   Jan 29 2014, 06:15 PM
r_towle   oh DUH.... My Eurovan has this. Look for the temp...   Jan 29 2014, 06:25 PM
andys   The circuit logic in BIGCAT83's schematic (how...   Jan 29 2014, 07:36 PM
computers4kids   Lots of great information. OK. I'll run two ...   Jan 29 2014, 09:07 PM
Andyrew   When I had my overheating problems (and still do.....   Jan 29 2014, 10:40 PM
jimkelly   c1 and c2 represent sensors that when active creat...   Jan 30 2014, 07:17 AM
76-914   Yes, c1 & c2 are grounds which when are contro...   Jan 30 2014, 09:06 AM
jimkelly   thanks : ) back to graphic.   Jan 30 2014, 09:22 AM
computers4kids   I went ahead and totally rewired my dual electric ...   Feb 1 2014, 08:15 PM
Mike Bellis   Any ideas how to source a 200 degree sensor that ...   Feb 1 2014, 09:32 PM
- Lo-Fi Version Time is now: 29th January 2025 - 10:57 PM
