Fender well liner GB set of 4 -, GB closed but adding to Black friday sales for those that want |
Mikey914 |
Apr 18 2012, 10:58 AM
The rubber man Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've been working on these for a bit and looks like I got these figured out and will have a set installed Saturday when I have some time. I'll be cutting these Friday for the test fit.
Also looking at an option to allow for a rubberedge so there will be a better seal and reduce any vibration noise. Might add $3-4 per liner but I need to install to see how well it works. Right now I'm looking at having production available after WCR may have a few sets before pending the test fit. Also will have additional material available to modify for the flared cars that will require the installer to cut the contour and glue to the stock. if you are interested let me know here. Attached image(s) |
edrotol |
Jan 30 2014, 01:42 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
I've been working on these for a bit and looks like I got these figured out and will have a set installed Saturday when I have some time. I'll be cutting these Friday for the test fit. Also looking at an option to allow for a rubberedge so there will be a better seal and reduce any vibration noise. Might add $3-4 per liner but I need to install to see how well it works. Right now I'm looking at having production available after WCR may have a few sets before pending the test fit. Also will have additional material available to modify for the flared cars that will require the installer to cut the contour and glue to the stock. if you are interested let me know here. interested pending on how it it is installed. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:17 AM |
