Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I've been working on these for a bit and looks like I got these figured out and will have a set installed Saturday when I have some time. I'll be cutting these Friday for the test fit.
Also looking at an option to allow for a rubberedge so there will be a better seal and reduce any vibration noise. Might add $3-4 per liner but I need to install to see how well it works. Right now I'm looking at having production available after WCR may have a few sets before pending the test fit. Also will have additional material available to modify for the flared cars that will require the installer to cut the contour and glue to the stock. if you are interested let me know here. Attached image(s) ![]() ![]() ![]() |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
We'll worth it My liners are holding up well and I'm no longer getting crud collecting by the doors or turnsignal buckets.
Mikey914 |
We'll worth it My liners are holding up well and I'm no longer getting crud collecting by the doors or turnsignal buckets. Jim Has helped in the prototyping and played around with these to help me get these started. I'm just needing to finalize the pattern by checking the fits myself to start the production and get the metal clips fitted properly. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:41 AM |
