Adjustable Temp Electric Fans, Need help finding a sensor--page 2 |
computers4kids |
Jan 28 2014, 09:11 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Currently I have dual electric fans, each on their own relay, that both come on around 180 degrees. I would like to reduce the fan noise from both fans coming on at once since my system stays cool easily and both fans tend to be overkill. I was thinking about having one fan come on around 180 degrees and the other come on if the temperature raises 10 degrees or so above. Fans 1 and 2 would also shut themselves off once each one dips 10 degrees below their set temps.
I see Jegs sells a kit that appears to do just this for around $150 that would control both fans. http://www.jegs.com/i/Derale/259/16789/10002/-1 Another possibility, would be to let Fan 1 continue to come on at 180 using the temp sender Renegade supplied, disconnecting the Fan 2. Jegs also sells the same adjustable unit for a single fan for $83. I would connect Fan 2 using the single controller for half the price. http://www.jegs.com/i/Derale/259/16779/10002/-1 What are your thoughts? |
computers4kids |
Feb 1 2014, 08:15 PM
I went ahead and totally rewired my dual electric fan setup using three relays and BigKat's diagram.
The only thing left to do is purchase a thermo switch to screw into my rod simpson radiator where their is an extra port that is capped at the top of the radiator. I brought the plug with me to my FLAPS and they couldn't figure out which one (application) that would screw in...GEEZ! I thought that would be the easy part. Any ideas how to source a 200 degree sensor that is the right size for my radiator? Attached image(s) |
Mike Bellis |
Feb 1 2014, 09:32 PM
Resident Electrician Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Any ideas how to source a 200 degree sensor that is the right size for my radiator? http://www.summitracing.com/search/departm...size/3-8-18-npt Assuming is is a 3/8" NPT thread... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 29th January 2025 - 11:05 PM |
