kevin311 |
Member ![]() ![]() Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None ![]() |
I've been running Megasquirt II for a while now on my 71 1.7 with the stock D-jet components and it has been running well. But everything is looking tired in the engine bay and I am planning on taking out the engine to clean everything up and install SS fuel lines.
Then I remembered seeing a video youtube with an australian guy reviewing his 914 and he mentioned having GSXR ITBs on his car. Sounds like a fun project to me so I started researching and think I have found an even better solution. The throttle bodies I found are from a 2001 Honda VFR800. The bike is a V4 so the TBs and fuel rails are already split into pairs, and have a linkage that connects both. They have 37mm throats, and came with the throttle position sensor, fuel pressure regulator , injectors and and all the wiring and connectors. Also the brackets on the sides already have a tab for throttle cable. The injectors are high impedance so I wont have to run PWM on Megasquirt anymore and hopefully can get an even finer tune. I'm also thinking about switching the PCs for 96mm, but I think that will wait until later, but you never know this started out as an engine cleaning... The only things I need to figure out are the flow rate of the injectors, where I'm going to hook up the IAT sensor, and will need to build a vacuum plenum. Also these injectors run at 36 psi, can the stock fuel pump handle that or do I need to look for another solution? Here are some pics, check out how close the spacing is for weber manifolds. Please excuse the dirt. I still haven't cleaned them up. This is gonna be fun. (IMG:style_emoticons/default/beerchug.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224315.1.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03555.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224325.2.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03552.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03558.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224346.3.jpg) (IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03559.jpg) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,271 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
This is a cool project, but I think that you are going to want to rethink you throttle linkage. It is going to really screw with you on idle speed.
Air cooled motors grow when hot, and the Type IV can grow somewhere close to an inch in width from cold to hot. That is gonna change the length required by that cross rod. It also explains why the linkage on a 911 engine looks like it does, with the crossbar that pivots. |
Lo-Fi Version | Time is now: 20th April 2025 - 07:32 PM |
