> Mark's ADHD/ADD/DWD 3.0 /6 conversion thread, Woohoo! It runs awesome, but it's never done....
Mark Henry
post Feb 5 2014, 03:15 PM
that's what I do!
First I'm 52, so I'm not in danger of dying of old age any time soon (knock on wood), but if I don't get it in gear and get this done I'll be too old to enjoy it. My 914 has already been off the road since 2009 and that is just too long. Life has gotten in the way these past 4 years and deciding to homeschool my two kids with me going part time work (so low funds), full time teacher (so no time) didn't help.
But I have been picking away at jobs and collecting parts and I'm pretty well ready to make the push to get it done. Also my boy has decided to go back to regular school (starts next week) and the girl is super easy to teach by herself.
I'm also pushing to get my almost completed '67 VW bug project done as well.
The bug engine is where this started, I a quest for power I began building a type 4 2.6L engine for my 914, then I got sexed up by the /6 (IMG:style_emoticons/default/wub.gif)
I'll start a VW bug thread (later) to keep the 2 projects separate.
So what have I collected so far???
Well.... here's my build sheet...
Engine build sheet for 3.0 1974 914 six conversion.
Engine 3.0L, 70.4mm X 95mm, 10.5: 1 CR
Case, 1979, 3.0, serial # *6399XXX, 930/13, 930.101.104.4R, Supertec head studs
Crank, stock, std/std, polished and magnafluxed, converted to CW distributor drive gear
Rods, stock, rebuilt big and small end, new bushings, ARP bolts and nuts
Flywheel stock, with custom 914-901 adapter ring, CSP 228mm bus HD pressure plate
Full engine balance, pressure plate and adapter ring balanced separately
Main bearings, new glyco, DFL (Dry Film Lube) coated
#8 Main bearing, original Porsche, DFL coated
Rod bearings, new glyco, DFL coated
Intermediate shaft bearings, new Porsche, DFL coated
Gasket set, new nose and rear main seal, Supertec sealant kit
Pump, stock, cooler stock 911 modified to 914/6 spec
Pistons, Mahle, new, 3.0 custom RSR, DFL coated skirts, ceramic coated tops, Goetze rings
Cylinders, stock 3.0 nickasil, replated Milenium/LN engineering, stock gaskets, .025mm base gasket
Heads, 3.0 big port, minor port work, twin plug
Valves, stock size, exhaust new TRW sodium, intake new AE
Valve springs, Eibach 20444.212, retainers early stock, keepers stock modified
Ceramic chambers and exhaust ports
Cams, WEB-CAM, 120/104, set at 5.2mm/.10 lash, 964 cores modified to 901 spec
Towers, spray bars R&R, tapped and cleaned, rockers resurfaced and rebushed, RSR rocker shaft seals
Chains, new IWIS, new cam sprockets, keys and pins
Tensioners, hydraulic, no fail modification
906 style cylinder cooling deflectors
Cooler, stock, 3.0, modified for 914
Oil tank, DWD
Oil, Brad Penn break in, Delo400 15w40
Oil filter, Mahle OC54 (late 911)
Carburetors, Weber 40mm IDA, rebuilt, new carb kits, 34mm venturis, 155 main jets, F3 emulsion tubes, 180 air correction, 55 idle, Ported stock manifolds, custom phenolic spacers.
K&N filters and rain hats, Weber linkage
fuel pump
Distributor, PMS/Jarvis, CW, MSD internals, Jaguar XJS-12 cap (1989-1996), Jarvis rotor (RSR clone)
Plug wires custom labeled twin plug, Patrick Motorsports
Ignition, MSD 6AL, twin MSD high vibration coils, max RPM 6800
Spark plugs, NGK BPR5ES (BPR6ES also available for tuning)
Headers, 914, 1-1/2” MSDS, ceramic coated
Muffler/collector, stock banana
14point7 wideband O2 meter, custom wire harness
Transmission
914, 901, side shift rebuilt, using good used parts
Gasket set, Elring
Gearing, custom, A,F,O,X, HB
Stub axles 108mm 911/901
Axles, Sway-Away custom, part# 2420, directional L and R mark to the outside
CV, Lobro, G50 108mm modified to '1969-1974 spec grease seals
Rear hubs and stubs, 5-bolt Porsche, 1972 911, new bearings
Bilstein, shocks, 140lb springs
Front struts, 914/6, Bilstein struts, 5-bolt hubs,
Turbo tie rods, ball joints, and bearings all new German.
Free Motion needle bearings for the front, Original Customs
Sway bars, 22mm Tarret front and stock rear
Front calipers, Brembo aluminum, Alpha Romeo GTV-6/Milano (1984-86), rebuilt with 911M kits
Front pads, 1971-72 bus modified,
Front rotor stock vented 914/6, drilled
Rear calipers, stock 914/4 modified for vented rotor (spacers) rebuilt, stock rear pads
Rear rotor stock vented 911, diameter reduced 5mm (10mm total)
Fuchs 1975 “020” 5-bolt Porsche, refinished
Spare 944 turbo aluminum space saver
I still have to make/buy the oil lines and I have to mod the front cooler.
New project this year 2021 is a SDS fuel injection twin plug system using a modified 964 plenums. Write up coming soon.
Mark Henry
post Feb 6 2014, 07:21 AM
that's what I do!
Getting my kit together for the balance work, a couple of questions ....
I stick with the 930 pulley right?
And the big fan pulley is for the 930 crank pulley I assume???
Mark Henry   Mark's ADHD/ADD/DWD 3.0 /6 conversion thread   Feb 5 2014, 03:15 PM
Kirmizi   :popcorn:   Feb 5 2014, 04:18 PM
Mark Henry   First the foundation of my build, a 1979 3.0 case,...   Feb 5 2014, 04:41 PM
Mark Henry   A job I just tackled was loctite epoxy on all the ...   Feb 5 2014, 04:51 PM
PanelBilly   So similar, but the kids are grown and I have a fe...   Feb 5 2014, 04:58 PM
Mark Henry   One thing this build will have that I've never...   Feb 5 2014, 04:59 PM
Mark Henry   Big snow storm today kids want me to take them ski...   Feb 5 2014, 05:04 PM
396   Who are you going to use for the piston crown ther...   Feb 5 2014, 05:25 PM
396   Who are you going to use for the piston crown the...   Feb 5 2014, 09:24 PM
Mark Henry   Who are you going to use for the piston crown the...   Feb 5 2014, 10:54 PM
396   Who are you going to use for the piston crown th...   Feb 5 2014, 11:53 PM
shuie   awesome. Thanks for sharing. Do you have any more...   Feb 5 2014, 06:12 PM
Mark Henry   awesome. Thanks for sharing. Do you have any mor...   Feb 5 2014, 08:55 PM
shuie   Sure.... what do you want to know? Made my own a...   Feb 6 2014, 10:00 AM
r_towle   Mark.....look a chicken.... Oh, is it time for sk...   Feb 5 2014, 06:13 PM
Dr Evil   :popcorn:   Feb 5 2014, 06:50 PM
Mark Henry   :popcorn: The good doctor was a great help in th...   Feb 5 2014, 09:00 PM
cwpeden   How was skiing? Just got back from 5 days with th...   Feb 6 2014, 12:48 AM
Mark Henry   How was skiing? Just got back from 5 days with t...   Feb 6 2014, 07:11 AM
Woody   :popcorn:   Feb 6 2014, 07:18 AM
Mark Henry   Getting my kit together for the balance work, a co...   Feb 6 2014, 07:21 AM
MrHyde   Doesn't sound too bad Mark… Atleast you didn...   Feb 6 2014, 07:23 AM
Philip W.   Mark, thanks for posting this thread, i will enjoy...   Feb 6 2014, 07:25 AM
MDG   :mellow:   Feb 6 2014, 09:02 AM
Maltese Falcon   Mark, keep up the good work...nice details as well...   Feb 6 2014, 09:42 AM
Mark Henry   Mark, keep up the good work...nice details as wel...   Feb 6 2014, 10:30 AM
AfricanHijinx   :popcorn:   Feb 6 2014, 10:32 AM
914Timo   I have been waiting for this thread. Thanks for sh...   Feb 6 2014, 01:51 PM
76-914   So you finally decided to jump into the "aren...   Feb 6 2014, 02:01 PM
sic6   So you finally decided to jump into the "are...   Feb 10 2014, 01:10 PM
Mark Henry   So you finally decided to jump into the "ar...   Feb 10 2014, 03:02 PM
Van914   mark, I miss my 3.0 914. I did not go as far as yo...   Feb 6 2014, 04:25 PM
Mark Henry   mark, I miss my 3.0 914. I did not go as far as y...   Feb 6 2014, 05:31 PM
r_towle   Flares....... Squirrels... Skiing Oil cooler C...   Feb 6 2014, 08:48 PM
Mark Henry   Flares....... Squirrels... Skiing Oil cooler ...   Feb 6 2014, 09:49 PM
r_towle   Turbo, 400 hp or more on tap... Shop talk forums.....   Feb 6 2014, 08:57 PM
Mark Henry   Checked to make sure it still worked. I knocked i...   Feb 6 2014, 09:51 PM
Mark Henry   I had this old top hanging around. I bent up the b...   Feb 6 2014, 09:54 PM
Mark Henry   Then I cut in the control panel :)   Feb 6 2014, 09:58 PM
r_towle   Ok, how did you bend that with no brake?   Feb 6 2014, 10:02 PM
balljoint   Ok, how did you bend that with no brake? By han...   Feb 6 2014, 10:05 PM
Mark Henry   Ok, how did you bend that with no brake? Two pie...   Feb 6 2014, 10:08 PM
Mark Henry   Not quite finished, I still have to mount the top ...   Feb 6 2014, 10:03 PM
r_towle   Impressive.   Feb 6 2014, 10:11 PM
mrbubblehead   now you can do some home powder coating too. i can...   Feb 6 2014, 10:13 PM
Mark Henry   Did I also mention I'm training for my black b...   Feb 6 2014, 10:14 PM
PanelBilly   Don't you need to drill a hole for the exhaust...   Feb 6 2014, 11:28 PM
Mark Henry   Don't you need to drill a hole for the exhaus...   Feb 7 2014, 06:14 AM
Mark Henry   Fired it up today with my laser thermometer pointe...   Feb 7 2014, 10:44 AM
PanelBilly   Fired it up today with my laser thermometer point...   Feb 8 2014, 06:48 PM
r_towle   leave it and mark it so you dont forget. Make a s...   Feb 7 2014, 11:16 AM
Mark Henry   Doh....squirrel!!!! Gots to keep ...   Feb 8 2014, 11:58 AM
Mark Henry   I'm getting my "poop in a group" to ...   Feb 8 2014, 02:26 PM
Mark Henry   The ring was made from a type 1 VW beetle flywheel...   Feb 8 2014, 02:34 PM
Mark Henry   Believe it or not this was made on my 1942 Montgom...   Feb 8 2014, 02:38 PM
kid914   :popcorn: WOW a 300+ hp 3.0 rsr engine???? :head...   Feb 8 2014, 03:30 PM
McMark   Can you weigh the flywheel w/ adapter as well as t...   Feb 8 2014, 03:38 PM
Mark Henry   Can you weigh the flywheel w/ adapter as well as ...   Feb 10 2014, 11:12 AM
MrHyde   Nice Lathe ! When did you get that !   Feb 8 2014, 05:12 PM
Mark Henry   Nice Lathe ! When did you get that ! A...   Feb 9 2014, 07:19 AM
sixnotfour   once you start baking powder , You will wish the c...   Feb 8 2014, 08:38 PM
Mark Henry   Decided to make my adapter ring holes a little big...   Feb 9 2014, 10:12 PM
Mark Henry   Also decided that I should also mark the flywheel ...   Feb 9 2014, 10:27 PM
mrbubblehead   Also decided that I should also mark the flywheel...   Feb 9 2014, 10:50 PM
Mark Henry   Also decided that I should also mark the flywhee...   Feb 9 2014, 10:53 PM
Mark Henry   Rebult rods with ARP bolts Aaaahhhhh....reaming a...   Feb 9 2014, 10:37 PM
PanelBilly   Can I just send my engine parts to you and you can...   Feb 9 2014, 10:39 PM
Mark Henry   Can I just send my engine parts to you and you ca...   Feb 9 2014, 10:43 PM
PanelBilly   Can I just send my engine parts to you and you c...   Feb 9 2014, 11:47 PM
Mark Henry   [quote name='Mark Henry' post='1995824' date='Feb...   Feb 10 2014, 06:06 AM
Mark Henry   Last thing for today is I swapped out the dizzy dr...   Feb 9 2014, 10:47 PM
McMark   Cool! My aluminum flywheel is about 3 lbs and...   Feb 10 2014, 03:47 PM
Mark Henry   Cool! My aluminum flywheel is about 3 lbs an...   Feb 10 2014, 04:06 PM
PanelBilly   Why reverse the gear on the dizzy?   Feb 10 2014, 04:41 PM
Mark Henry   Why reverse the gear on the dizzy? Not just a ma...   Feb 10 2014, 10:31 PM
mrbubblehead   WOW! That is gonna be one nice engine Mark.   Feb 11 2014, 12:55 AM
Mark Henry   Thanks :) Anyone doing full rebuild on a SC eng...   Feb 11 2014, 05:48 AM
Mark Henry   Got to keep thinks rolling Next job is the cam to...   Feb 11 2014, 10:13 PM
Mark Henry   First I pull the factory plugs and then the spray ...   Feb 11 2014, 10:17 PM
Mark Henry   The cam towers are now a little cleaner, this clea...   Feb 11 2014, 10:21 PM
mrbubblehead   mark, i have been using aircraft stripper on engin...   Feb 11 2014, 10:44 PM
Mark Henry   Been feeling like shit...figured as much but it lo...   Feb 12 2014, 02:45 PM
balljoint   Take a break. Drive to Brampton. :whistle:   Feb 12 2014, 03:09 PM
Mark Henry   Take a break. Drive to Brampton. :whistle: Pla...   Feb 12 2014, 03:37 PM
Mark Henry   dp   Feb 12 2014, 03:56 PM
Mark Henry   Working a bit slow today, but stiff upper lip got ...   Feb 12 2014, 03:57 PM
Mark Henry   The plug and the fresh tapped hole. This is how it...   Feb 12 2014, 04:01 PM
Mark Henry   While doing this it's a good time to chase the...   Feb 12 2014, 04:06 PM
Mark Henry   Now....you're asking yourself why the hell is ...   Feb 12 2014, 04:41 PM
Mark Henry   So I've been using Dr Evils favorite cleaner L...   Feb 12 2014, 04:46 PM
Mark Henry   Guess what I'm making :)   Feb 13 2014, 09:02 PM
Mark Henry   First hint it's not finished...damn belt for m...   Feb 13 2014, 09:11 PM
PanelBilly   HE for /6s?   Feb 13 2014, 09:13 PM
Mark Henry   HE for /6s? :lol: Another hint other side o...   Feb 13 2014, 09:41 PM
Mark Henry   next..   Feb 13 2014, 09:44 PM
Mark Henry   :) It's a jig for...???   Feb 13 2014, 09:51 PM
bigkensteele   :) It's a jig for...??? ITB adapters?   Feb 13 2014, 09:59 PM
gms   :) It's a jig for...??? restrictor plates f...   Feb 13 2014, 10:08 PM
Mark Henry   Close.....custom phenolic spacers :) The jig will...   Feb 13 2014, 10:26 PM
Justinp71   Nice thread! A carbed 3.0 is an awesome engine...   Feb 14 2014, 12:16 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 20th April 2025 - 03:42 AM
