McMark |
I'm building this 2270 and I thought this would be a good one to document. I'm going to try and cover every little aspect of the build, although I'm not necessarily going to break down every process into a step by step.
I'm starting with a 1.7 'W' case. I did a quick line bore check and it's a nice STD case. But more on that later when I actually measure the line bore accurately. Case Preparation - In this section I'm covering all the modifications and inspections to be done on the bare case. Threaded Gallery Plugs, Resurface Oil Filter Mount I used my slide hammer setup to pull the original gallery plugs. I'm just doing the 'normal five'. In this picture also shows the oil filter mount face - I pull the studs and true the surface up to ensure a good, leak-free seal. ![]() HV Oil Pump I have a Schadek oil pump that I've cut in half to mark the case for 'port matching' the oil pump. The ports on the case are smaller than the oil pump, so this simply eases the transition. I use a carbide cutter for aluminum in a pneumatic die grinder to carefully open up the holes. ![]() ![]() Cleaning Stud Threads I chased all the M8x1.25 studs on the case. This eases installation, but also ensures more accurate torque. Any fastener that has a specific torque value should have clean threads. The rust/dirt/sealant/etc on the surface will make the fastener harder to turn, which means you're getting a slightly false torque reading. You'll see the head studs have all been removed. I don't use a tap or die to clean the head stud or the case threads because I've seen this result in loose head studs. I don't touch this parts of the case, and I use a wire wheel on the bench top grinder to clean the threads without risk of removing material. ![]() |
McMark |
They absolutely have blown on people. You see a thread pop up about it every 6 months or so. But only those five because the rest are smaller. The oiling system all sees the same psi, but if you actually do the math on psi as pounds per square inch it's lower force. This is an incorrect, oversimplification, but essentially a 1" plug at 50 psi, sees 50 pounds of force where a 1/2" plug at 50 psi would see 25 pounds of force. Right idea there, just bad math (the are area of a 1/2" plug isn't half of a 1" plug).
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
They absolutely have blown on people. (IMG:style_emoticons/default/bye1.gif) My old 1.8 did. I started the car, the oil light came back on again, I reved it a little, the light went out and came on again. I shut it off right there, and got out to look. I saw the plug and the nice puddle of oil--it was quite sizeable! My mechanic replaced the plug (I think with another expansion plug, but I'm not sure) and re-filled the oil and I was good to go. --DD |
rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
Hey Mark, what's the plan for induction? (Sorry if you mentioned it and I missed it)
McMark |
Hey Mark, what's the plan for induction? (Sorry if you mentioned it and I missed it) MicroSquirt of course. (IMG:style_emoticons/default/beerchug.gif) Might build a custom set of stock style intake runners and plenum, but sized larger. Can't fantasize about that too much just yet. There's still a lot of work to do on the motor. |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,931 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Hey Mark, what's the plan for induction? (Sorry if you mentioned it and I missed it) MicroSquirt of course. (IMG:style_emoticons/default/beerchug.gif) Might build a custom set of stock style intake runners and plenum, but sized larger. Can't fantasize about that too much just yet. There's still a lot of work to do on the motor. Think I have said this a few times now, but check out the later 2.1 Vanagon throttle body. 50mm, bolts to the 1.8 plenum, and has a few other neat things about it. You just want to massage out the opening on the plenum a bit to match the larger size. Intake runners on the 1.8 are the largest stock diameter you can get (same as the 2.0 914 setup) |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:12 PM |
