New 'Hobby' Project, carb tuning gone high tech |
McMark |
Oct 15 2013, 10:39 PM
EDIT: I know about tube-and-water setups. You can't drive with those. I'm building some different.
I've been pondering this project for awhile, and now I'm finally getting ready to start. Every time I synch carbs I think about how terrible and approximate the process is. What I'm going to try is using a small, programmable computer called an Arduino. There are add-ons called Shields to expand the functionality, and I'm using a LCD screen shield. I'm going to hook up 4 to 6 MAP sensors to the Arduino and output their readings on the screen. Using this tool, I'll be able to numerically evaluate the relative balance of the carb throats. One possible shortcoming is that the intake pulses may create fluctuating values that are difficult to interpret. Although, I have some ideas that may deal with this. Some sort of averaging could help. (IMG:style_emoticons/default/idea.gif) Here's what the Arduino looks like (this is the Uno version) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898348.1.jpg) Here's the screen shield (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898349.2.jpg) Here's the MAP sensors I'm going to start with. (IMG:http://www.914world.com/bbs2/uploads_offsite/thumbs4.ebaystatic.com-419-1381898350.3.jpg) I'm also probably going to have to make some plates that will go between the carb and manifold with a vacuum port on it. This would be the easiest way to access manifold vacuum since I can't count on carbs to have vacuum ports. Oh, and this will also be useable while driving to evaluate dynamic synch. |
stugray |
Feb 9 2014, 01:03 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Mark,
I thought about another excellent use for your arduino project: http://www.arduino.cc/en/Tutorial/KnockSensor & http://www.ebay.com/itm/E46-bmw-m3-s54-kno...093&vxp=mtr Your arduino should have 6 Analog inputs. SO you should have two left. You could put one knock sensor on each head. I am also playing with a arduino that could be used for variable ignition timing. It would have a programmable advance curve based on RPM. Then you could make it change timing based on:RPM Manifold pressure (load) and input air temperature. If you had the knock sensor, it could retard timing if knock is detected. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:27 AM |
