LS1 or V8 914? |
LS1 or V8 914? |
piss'n914 |
Jan 31 2014, 04:16 PM
Newbie Group: Members Posts: 10 Joined: 31-January 14 From: United States Member No.: 16,944 Region Association: Southern California |
Hey guys, I've very new to this whole thing. I'm still trying to figure out what is exactly wrong with my 914 (starting and running issue). But whats the possibility or reliability of installing a v8 or v6....other than the immediate install cost. what do ya'll think.
mittelmotor |
Feb 9 2014, 09:20 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Here are a few more pics that show the opening in the rear trunk require for the induction system, etc. Someday I'll make a cover to neaten it up somewhat! People have asked about whether the engine gets enough induction air, but it seems to be fine…drawn in through the latch-cup holes and around the edges of the TB cutout.
andys |
Feb 10 2014, 03:16 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Here are a few more pics that show the opening in the rear trunk require for the induction system, etc. Someday I'll make a cover to neaten it up somewhat! People have asked about whether the engine gets enough induction air, but it seems to be fine…drawn in through the latch-cup holes and around the edges of the TB cutout. I was looking at your throttle body; if that's a late LS1, did you end up with a real long gas pedal travel? On mine, I replaced the LS1 with a truck throttle body since it has a smaller throttle cam (like an early LS1 but way cheaper), which helped shorten the pedal travel. Andys |
mittelmotor |
Feb 11 2014, 10:52 AM
Here are a few more pics that show the opening in the rear trunk require for the induction system, etc. Someday I'll make a cover to neaten it up somewhat! People have asked about whether the engine gets enough induction air, but it seems to be fine…drawn in through the latch-cup holes and around the edges of the TB cutout. I was looking at your throttle body; if that's a late LS1, did you end up with a real long gas pedal travel? On mine, I replaced the LS1 with a truck throttle body since it has a smaller throttle cam (like an early LS1 but way cheaper), which helped shorten the pedal travel. Andys Yes, I'm using the stock throttle cam and stock 914 cable linkage, so the throttle opens only about 80 percent, which is plenty for me! Also will make the transaxle live a long and happy life. (IMG:style_emoticons/default/biggrin.gif) Truck TB sounds like the way to go for full throttle. Throttle pedal travel on mine is stock. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:19 PM |
