McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
EDIT: I know about tube-and-water setups. You can't drive with those. I'm building some different.
I've been pondering this project for awhile, and now I'm finally getting ready to start. Every time I synch carbs I think about how terrible and approximate the process is. What I'm going to try is using a small, programmable computer called an Arduino. There are add-ons called Shields to expand the functionality, and I'm using a LCD screen shield. I'm going to hook up 4 to 6 MAP sensors to the Arduino and output their readings on the screen. Using this tool, I'll be able to numerically evaluate the relative balance of the carb throats. One possible shortcoming is that the intake pulses may create fluctuating values that are difficult to interpret. Although, I have some ideas that may deal with this. Some sort of averaging could help. (IMG:style_emoticons/default/idea.gif) Here's what the Arduino looks like (this is the Uno version) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898348.1.jpg) Here's the screen shield (IMG:http://www.914world.com/bbs2/uploads_offsite/www.adafruit.com-419-1381898349.2.jpg) Here's the MAP sensors I'm going to start with. (IMG:http://www.914world.com/bbs2/uploads_offsite/thumbs4.ebaystatic.com-419-1381898350.3.jpg) I'm also probably going to have to make some plates that will go between the carb and manifold with a vacuum port on it. This would be the easiest way to access manifold vacuum since I can't count on carbs to have vacuum ports. Oh, and this will also be useable while driving to evaluate dynamic synch. |
McMark |
Not for me. At least at this time. I've picked my path and I'm gonna see it through until I get something I consider a working setup. Then I may move on to MAF. But MAP is so much easier to set up in the car and I can't imagine how to make a MAF setup that even comes close to that simplicity.
Although, maybe if I built the MAF into a package that would bolt onto the top of the carbs in place of an air cleaner... (IMG:style_emoticons/default/idea.gif) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Not for me. At least at this time. I've picked my path and I'm gonna see it through until I get something I consider a working setup. Then I may move on to MAF. But MAP is so much easier to set up in the car and I can't imagine how to make a MAF setup that even comes close to that simplicity. Although, maybe if I built the MAF into a package that would bolt onto the top of the carbs in place of an air cleaner... (IMG:style_emoticons/default/idea.gif) That is what I envision. Either on tubes angles centrally from the carbs, or just sticking straight up on shorter stacks. I typed MAF and Bosche into ebay and found some deals among the new parts that are much more. I do respect the MAP approach as it is cheaper and stupid simple. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:10 PM |
