Wednesday, 16 April 2025 |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,259 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I found something online that I wanted to try:
![]() I bought one and wired it to my factory 911 speedometer. I wired it like this: ![]() The white wires are from a 12v DC transformer, used to bench test it. The Positive is on the left, and the negative is on the right. The Autometer module is wired to the same positive and negative lugs, and the purple wire from the Autometer is connected to the speedo input. The other speedo input is jumped to ground. Running the calibration procedure in a bench test, found here , I was able to get the speedo to read exactly 80 mph, and the odometer was working too. The next step is to test it in a vehicle. The heavy wires from the positive and negative go to an old cigarette lighter plug that I will use to test it in my truck, comparing the output with the truck's speedo, and my android app "gps speedometer". If everything works as I expect, I can remove the speedo cable and angle drive from my car. I will probably plug the speedo output in the gearbox to prevent any gear oil leaks. I will update this when I run the second test. I will keep you updated on the results. |
ClayPerrine |
Mine came from a 76 911. But the easy way is to look at the face of the speedometer. It will have a reset button at the bottom, and under the VDO logo it will say "Electronic". Could you hook it up to a HUD? I suppose you could. But I was not looking for that. |
Lo-Fi Version | Time is now: 16th April 2025 - 09:24 AM |
