Radiator Question, what goes in here ? |
76-914 |
Feb 17 2014, 06:45 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
76-914 |
Feb 19 2014, 03:50 PM
Good one. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/beerchug.gif) And Cap't, it does appear to have a raised flange for washer contact. I was speaking of the flange on the plug that could be used there. The fan switches have that sealing area incorporated in the design. To answer the switch availability issue, the VW OE or OES switch would probably be best because it's readily available in a variety of temperature ranges, it's cheap, and it fits without fooling around. The paper gasket works fine, or you can opt for the copper washer. There's no relief for an o-ring, so that would be one of the last things I would look at for sealing the joint. The Cap'n All good info though I'll stay away from the crush washer. I'm afraid it wouldn't seal well against the plastic face of the radiator. I'm glad you've retired. It gives you more time to answer questions. (IMG:style_emoticons/default/biggrin.gif) never knew they made Sciroccos in 1990 (IMG:style_emoticons/default/poke.gif) How does that fit in the frunk? Any pics? Doug, Look in my build thread http://www.914world.com/bbs2/index.php?sho...=201776&hl= there are several shots of it installed. And maybe it was a Golf or Jetta. I'll have to look back. And somebody needs to set Wikipedia straight on this.......... Volkswagen Scirocco From Wikipedia, the free encyclopedia Volkswagen Scirocco VW Scirocco III 2.0 TSI front 20100410.jpg Overview Manufacturer Volkswagen Production 1974–1992 2008–present Body and chassis Class Sport compact Layout Front-engine, front-wheel-drive Chronology Predecessor Volkswagen Karmann Ghia The Volkswagen Scirocco is a sport compact coupe produced by the German manufacturer Volkswagen, undergoing two generations of development between 1974 and 1992 and reintroduced in a third generation in August 2008. |
Lo-Fi Version | Time is now: 28th December 2024 - 02:57 PM |
