> 1 1" hole, alt to unibit?
machina
post Aug 5 2004, 07:47 AM
Need to cut 1 1" hole in the rear firewall for a -10 bulkhead T for the accusump. My unibit doesn't go to that size and the one that does is $60.
Can I use a hole saw or large normal drill bit to cut thru the sheetmetal (already have those bits)? Don't want to screw it up.
hole will be right here...
Thanks,
dr
Brad Roberts
post Aug 5 2004, 07:54 AM
914 Freak!
Honestly.. do'nt put it right there. Sooner or later you will need a brace from the control arm ear forward and that area is perfect to tie into. VERY strong right there and the brace wont interfere with any engine setup you run.
B
synthesisdv   1 1" hole   Aug 5 2004, 07:47 AM
Brad Roberts   Hole saw. That is double thick right there. B   Aug 5 2004, 07:52 AM
Brad Roberts   Honestly.. do'nt put it right there. Sooner or...   Aug 5 2004, 07:54 AM
Brad Roberts   It appears you went "off" a few times. :evilgrin:...   Aug 5 2004, 07:55 AM
synthesisdv
- Lo-Fi Version Time is now: 6th January 2025 - 07:24 PM
