1 1" hole, alt to unibit? |
machina |
Aug 5 2004, 07:47 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Need to cut 1 1" hole in the rear firewall for a -10 bulkhead T for the accusump. My unibit doesn't go to that size and the one that does is $60.
Can I use a hole saw or large normal drill bit to cut thru the sheetmetal (already have those bits)? Don't want to screw it up. hole will be right here... Thanks, dr Attached image(s) |
machina |
Aug 5 2004, 07:59 AM
QUOTE(Brad Roberts @ Aug 5 2004, 09:54 AM) Honestly.. do'nt put it right there Thanks for the advice brad, I appreciate it. The accusump manual valve is really near the centerline but I thought putting the T near the center might interfere with the fan area, brake lines etc. The port into the oil gallies on my motor enter from the right side so I figured somewhere on the right side of the firewall was a good place. I want to do a clean install, maybe I'll put it higher up where the sheetmetal is not doubled up. dr |
Lo-Fi Version | Time is now: 6th January 2025 - 07:27 PM |
