Starter relay or no starter relay, Been reading up for an hour and still don't know!! |
David Stowers |
Feb 22 2014, 05:06 AM
Member Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
On two occasions recently on pulling onto my driveway after a long journey my car won't restart after turning off to unlock the garage door. Luckily I can then just push the car in but with a European tour booked in the summer I'd like to sort the problem.
When I get back in after opening the garage the lights on the dash dim when I turn the key to start but there is no click. 20 minutes later it will start right up. Is this the problem that will be solved by a hot start relay kit or just a good old fashioned sticky solenoid? I'd rather do just the relay or just replace the solenoid so which is it? Thanks guys |
type47 |
Feb 22 2014, 03:52 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Any suggestions for novel/unique/cool ways to mount the Ford relay? ... besides a stainless steel hose clamp around the starter (IMG:style_emoticons/default/dry.gif)
SLITS |
Feb 22 2014, 05:25 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Any suggestions for novel/unique/cool ways to mount the Ford relay? ... besides a stainless steel hose clamp around the starter (IMG:style_emoticons/default/dry.gif) Screwed mine to the underside of the rear trunk floor (actually drilled thru and welded a fastener from the top (1/4 X 20 or 6mm as I remember). |
Lo-Fi Version | Time is now: 27th December 2024 - 05:11 AM |
